Hello, My W50 Cybershot has a Flash error coming up after my wife accidently dropped it on vacation. When I have it on and shooting photos, it constantly has the E:91:01 error flashing on the screen. I have tried to initialize the camera and it always comes back after a few seconds. Thank you in advance for the help. L. Kansas.
I have a method to stop the E:91:01 error flashing on the screen.it were not solve the flash function but atleast you can use the camera without flash. 1)at setup do a initialize. 2)go to flash function to turn off the flash (must do it fast,b4 the E91:01 appear,if not you need to reset it again ) by now E91:01 will never appear.you can use it like normal,be sure not to turn on your flash again or go to night mode.if not you need to perform step 1 & 2 again.hope it help.
I got it rectified, using sony service center. They say, one of the capacitor damaged. They have replaced it. Mine is in warranty. They say, actual cost would be in INR 4000/-(for your information to compare).
They say, this error can come, if we click photos continuosly, the capacitor may get heated up. We need to give a gap of 3 to 4 seconds. Time to be given for the flash to get recharged after a click.
I reset the camare, however, even it doesnt display the error again, the flash seems to no longer work
Customer support at Sony may help- but it seems the drop did it no good at all. The chances are a new camera will be the cure
SOURCE: Sony DSC-W50 Flash Error code-E:91:01
Press Menu button
togle across from REC Mode to setup
togle down thrice from camera to setup 1
togle across into sub menu
togle down from four times to Initialize
togle across again to the sub-menu
togle up from cancel to OK
press center button to accept the OK choice
Screen changes and so press okay again
It should restart the camera
Opening on the 'Clock Set' screen
togle down to cancel and use the camera and make sure that you have the camera to flash, if it works try again in the Auto function.
If it is still not working do not worry follow the steps again two or three more times, As this is generally a software error message and not a hardware malfunction.
If it is working then don't forget to set your Clock.
i have a thesame problem about the CAMERA
I never dropped the camera, however I get the same error code and was wondering what to do???
i m facing the same problem in my camara and camara flash is also not working. can ny one ponit out where the problems is? is it in software of the camara or device??? advance thanks for ur valuble suggestions....
Prakash
Same error code - E:91:01 problem, when I switch on my camera. I have not dropped it. But surprising, it got corrected, suddenly for 5 to 6 hours and again the error had started.
I am badly need of solution
i ve the same problem....i inizialited whitout sucess:-(
i've the same problem at the flash...i inizialited but it was only a temporary solution:-(
I have the same problem with Sony DSS-T70. When i which on my camera i am getting the same error
CAMERA WILL NOT INITIALIZE, JUST GET A ACESS MESSAGE AND TURN CAMERA ON AND OFF I DID THIS 10 TIMES, HAD 91.1 ERROR, NOW CAMERA JUST REQUEST TO TURN OFF AND ON.
same
need to remove E:91:01 from showing, pictures are not clear and flash does not work
