When switched on the temperature comes down to about -12 C . does not come any lower but i hear a irregular hissing sound probably in the gas.
You need to cut it off. You may be doing a lot of damage there. If this freezer is 8-10 years old, you may want to go ahead and replace it. At least it will not give you any more problems.
SOURCE: FREEZER SOUNDS VERY NOISY
that because the internal fan is hiting the ice or has bad bushings you can hear the noise just with the door close because when you open the door there is a switch the one turns off the internal fan so when you close the door it turn on the fan again if you wants to hear that with the door open just open the door and push the botton swich with your fingers and you'll hear the noise
SOURCE: HOTPOINT FZA80 FREEZER
Red light is indicating temp is too high, this can be caused by a variety of reasons.
You need to call an engineer to sort the problem out.
SOURCE: FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
SOURCE: freezer doesn't work
my freezer defrosted it self and the red tryangle light stays on what is it
Yes it should. If he is able to re gas it , he would be able to find a leak as well. Isn't it good to have someone handy to work on these things. Let me know how this works out.
