Question about GN Netcom (9120-48) Wireless Headset
GN Netcom heatset buzz
I have a constant buzzing in the headset. I've tried adjusting the volume, adjusting the wheel on the back, unplugging, changed the battery, moved the base as far away from the phone as the cord will allow and no change.
Any suggestions?
  • aritche Feb 01, 2009
    It's a real pain. In fact, I have 2 such GN Netcom 9120 wireless headsets that I bought about 2 years apart, one for the office and one for the home.
    A home, i get buzzing, in fact now that i work from home most of the time, both units are there, and one is more buzzy than the other. Even at a 10 yards or 10 feet or 3 feet from the base station.
    I am on a trip now, and took one of them with me, and I am still plagued with the buzzing periodically. What should I try? Could the speakerphone be causing the interference, my laptop, other environmental, or is it some defect in the base unit or head set?
I had this problem a few months ago, make sure the small wheel on the side is set on A. (if you look closly at the wheel there are very small and hard to see letters on there.) this should get rid of the buzzing.
Posted on Mar 31, 2009
6ya staff
SOURCE:
The handset will lift when I press the mfb but I get no volume or mic from the headset. It does not seem to be communicating with the phone. Tried unplugging the power, but that didn't solve it. We...
Your solution will depend on what type of phone and headset you have. I have a Polycom 501 IP phone with a headset jack and a GN Netcom 9125. I'm not using the lifter right now, but I seem to recall that an easy way to make it work was to plug the curly cord of the phone's handset into the bottom of the base unit, so that the cord went from the base of the headset to the headset jack on the base of the phone.
Jul 11, 2011 | GN Netcom GN 1000 RHL Wireless Headset
Where is the mute button on gn9330??
On the headset where you change the volume it is also a button. Click it in towards the microphone.
Sep 21, 2010 | GN Netcom GN 9330 Wireless Headset
I have a gn9120 headset that i love. suddenly, callers are complaining that they can't hear me. Is there volume adjustment or is there a defect?
Volume adjustment is made by depressing the two + and - together until beep is heard
once beep is heard press the + button several times until louder bleep is heard this will increase transmission from headset and cure the problem
Steve
Jul 15, 2009 | GN Netcom GN 9120 Professional Headset
GN 9120 beeps constantly
Are you using the GN1000 Handset Lifter? And if so, are you playing music/radio through the speaker of your telephone? If this is the case the Lifter will be picking up the sound of the music coming from the telephone and interpreting it as an incoming call, hence sending a signal to the earpiece in the form of beeps. Just stop the music coming from the telephone and the beeps should stop.
If you are not playing music through the telephone, you may need to turn down the sensitivity adjustment on the back of the Lifter. Just turn the knob anti-clockwise a little bit and see if that eliminates the beeping. If the sensitivity adjustment is too high it will pick up every little noise that goes on around your desk and interpet them as the phone ringing.
If you are not using the GN1000 Handset Lifter, then the beeping may be the result of a sticking/stuck volume button on the earpiece. If you adjust the volume on the GN9120 it gives a beep when you reach the maximum or minimum volume. If a button is stuck down it will result in a constant beeping. A stuck button is generally not a user servicable problem, however a little bit of tinkering with the button may get it unstuck.
Nov 19, 2008 | GN Netcom GN 9120 Professional Headset
GN Netcom 9120 unexplained beeping
Actually what she was hearing was the ring tone in her headset when a incoming call comes in. The sensitivity on the handset lifter that picks up the ringing on a incoming call was set all the way up and was picking up interferance from the headset base as they have the tendency to buzz when placed right next to the phone. I just turned down the ringer sensitivity with the adjustment on the handset lifter and that took care of the problem. Thanks for your time.
Nov 06, 2008 | GN Netcom (9120-48) Wireless Headset
GN Netcom GN 6210 - headset, no worky
Not sure what you mean by won't turn on.
If you mean no dial tone when you take it out of the cradle, I have run into this. The solution is to unplug the power cord and then plug it back in which resets the unit.
May 27, 2008 | GN Netcom GN-6210 Consumer Headset
GN Netcom wireless headset volume adjustment
Transmit volume adjustment
Adjust the volume of transmitted sound according to personal preference.
To adjust the volume:
1. Make a telephone call and ask the person you are calling to assist
you.
2. Press the +/– buttons on the headset simultaneously for 2 seconds.
A beep will indicate when 2 seconds has passed.
3. Adjust the volume level by pressing the + or – button.
4. When the person you are speaking with fi nds the volume of your
voice appropriate, press the +/– buttons simultaneously for 2
seconds. This setting is now stored in the headset.
A Copy of the manual is avaliable at:
http://www.onedirect.es/files/GN%20Netcom-ES/GN%20Netcom%209120%20manual.pdf
You must have Adobe Reader to view it and the instructions are on page PDF page 3 or manual page 6. Adobe Reader is avaliable for download at:
http://www.adobe.com/products/acrobat/readstep2.html
May 21, 2008 | GN Netcom (9120-48) Wireless Headset
Cannot hear anything out of the earpiece of my GN netcom 9120 wireless headset
I was also experiencing the same problem (also after a power failure / storm) -- apparently good battery charge, connections ok, etc. I then tried removing the battery from the headset itself, waited 30 seconds, and then reinstalled the battery. This seems to have resolved the problem.
It is fairly easy to open the clamshell, but you will need a very fine Phillips screwdriver to remove the battery hold-in (it's really not a hold-down, it just keeps the battery in place. Reassemble the same way -- be sure to keep positive to positive and negative to negative.
Sep 01, 2007 | GN Netcom (9120-48) Wireless Headset
GN Netcom (9120-48) Wireless Headset Logo
349 people viewed this question
Top GN Netcom Radio Communications Experts
Steve Morris
Steve Morris
Level 1 Expert
Tom Chichester
Alan Palmer
Level 1 Expert
Are you a GN Netcom Radio Communication Expert? Answer questions, earn points and help others
