SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
SOURCE: Kenmore washer 90 series continue
Sounds like the fill switch needs to be replaced. A good way to test it is to set your machine on low fill and see if it fills past 3/4. If it does, it's the fill switch.
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
SOURCE: Whirlpool LSC8244DQ0 Top Load Washer won't agitate, won't spin, will fill and drain
you need a new lid switch google model number and order new one
