Kodak EasyShare Z612 Digital Camera Logo
Michael Blake Posted on Jul 25, 2007
My battery went dead and once I charged it and returned to the camera it had reset itself to the factory setting of 15 pictures. I have a 2.0 GB memory card and I can not remember the steps to allow the camera to take the additional photos that the memory card allows. If someone could give me the steps to this I would greatly appreciate it.
Chaslie
Level 1:
  • Contributor 1 Answer
  • Posted on Aug 31, 2007
Chaslie
Contributor
Level 1:
Answers
Questions
0
Helped
281
Points
Use the "MENU" button and follow the program to reset your camera to its card memory. evidently you must do this each time you change cards or battery.
Cant load pictures from my kodak z612 to my hewlett packard p6823W with windows 7 home premium
Go to Kodak.com and download the latest Easyshare software and install it on your computer. After, that, install drivers for the camera, and you should be able to share the pictures between the camera and computer.
Kodak easyshare z612 ... when i take pictures indoors the pictures are fine. However, when I take pictures outside the pictures are all washed out. It looks like an over exposure but I have tried all the...
hi, you have shutter unit defective. indoor works fine but outside too much over exposure..due to shutter unit has oil contaminated on blade or sand damaged. your local repair shop could charge you around $45 to 65 if they are willing to repair. Good Luck with you!
1helpful
I turn my camera on...it lets me set the date and
batteries: are you using Li ion batteries that are charged up?
Kodak EasyShare Z612 Shuts down after taking a few pictures.
Question : What batteries can I use in my digital camera, and how long do they last?
Battery life depends on how you use your camera, the type of batteries you select, and how you handle the batteries.
Your camera is compatible with: KODAK Li-Ion Rechargeable Battery KLIC-8000 and KODAK CRV3 Lithium Batteries: A non-rechargeable battery. (so your battery might be in need of a change)
Using Your Camera
Some features, such as reviewing pictures and using the flash, require more power than others. Follow these guidelines to get the best use of your batteries:
  • Limit the time your camera is in Review mode.
  • Limit your use of the flash.
  • Use the LCD Dimmer or Auto Power Off features, if available on your camera.
  • Transfer your pictures to your computer using a compatible power adapter, camera dock, printer dock, or memory card reader.
  • Check that the latest firmware is installed on your camera. See Software, Driver & Firmware Downloads.
Handling Your Batteries
  • Wipe the battery contacts with a clean, dry cloth before loading it in your camera.
  • When using your camera in temperatures below 41° F (5° C), carry spare batteries and keep them warm.
  • Do not discard cold batteries that do not work; they may be usable when they return to room temperature.
  • Do not allow batteries to touch metal objects, including coins. Otherwise, the batteries may short-circuit, discharge energy, become hot, or leak.
1helpful
Kodak Z612 won't turn on
while you turn try and turn it on slow twist and pull lens outwards(gently while power on /off) and it will retract back in and power on.Work perfectly after.
Enzomatrixx Da Gr8 One
2answers
Kodak z612 camera now underexposes all flash photos, and overexposes all outdoor photos.
Check your settings. You probably have something set on manual control. Just set the camera's settings for automatic and you should be good to go.
2helpful
Kodak EasyShare Z612 Digital Camera Error #803
This problem is frequently due to corroded battery terminals inside the camera. Remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Kodak easy share z612 will not turn on to take a picture
When the battery dies, usually the camera will retract the lens if possible. If the battery is so dead the lens can not retract, I would recommend trying to charge or change the battery. Or try to turn the camera on, and then manually shutting it off if you can.
Lifeless Camera
I wish I shared you easy solution feeling. Try a few things Take battery out and clean the contacts at the base of the chamber with a pencil eraser. Ditto on the chamber door. If nothing happens try charging the battery in another charger or another battery. Still dead? Kodak support is the next stop
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
