Sony KDS-60A2000 60" HDTV Logo
Posted on Jan 29, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sony High Definition Projection TV Standby light flashing nine times, tv will not come on.
Model # kdp-51ws655
In the beginning, it would flicker and then go black. You could unpluge it for a while and pluge it back up and it would come back on. Now you can pluge it back up and the standby lignt just flashes nine times and pauses then blinds nine more times, and will not come back on. Can anyone tell me what is wrong or how to fix it, Thanks
I have a 2006 Sony SXRD with the same problem.
Mark Hammonds
Level 2:
  • Expert 61 Answers
  • Posted on Jan 29, 2009
Mark Hammonds
Expert
Level 2:
Answers
61
Questions
Helped
16102
Points
121
You could have a bad lamp i have seen new ones do the same thing if not you may have a bad power supply
Tv doesn't want to turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
2answers
Hello, I have a problem with my sony rear projection tv. When I try to turn it on the standby lights blink but it odes not turn on. I turned it on using display 5 vol- power and it did turn on and know it...
You need to count the number of blinks between the pause. Most common is 9 blinks. Also- after you press POWER, do you hear a "click" or not? If no click and 9 blinks, you probably have a "zero cross failure" and have two options:
(1) Replace the "G" board (part # A1054157A) or have it repaired (they repair it on eBay for about $40. You ship them the bad board and they either repair and return or ship you a different repaired board) A new board costs about $80- without having to send them your board.
(2) Repair the board yourself- by replacing the two diodes on the "G" Board - (D6301 which is on top- by the small transformer) and (D116 which is an SMT component on the bottom of the board- it takes VERY steady hands and a good solder iron). The parts should cost less than $25 and are available on eBay by searching for "sony a1054157a".
Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-2.jpg Location of "G" Board on a Sony Rear Projection TV (KDP-51WS655)
problem-4ojfzua2t5qdonett1db0kz0-5-5.jpg Component D6301 location (Sony KDP-51WS55)
problem-4ojfzua2t5qdonett1db0kz0-5-9.jpg Component D6116 location (Sony KDP-51WS55)
Standlight flashed 8 times
you will need a ohm meter.....check IC406, audio amp,PS401, PS402,flyback T8005 high voltage on D board,.....you can get parts at Mats Electronics # 1-800-628-1118
4helpful
2answers
My SONY HD projection TV KDP-51WS550 (2005) suddenly lost the picture and the Stand By /Timer light starting flashing 5x and then repeating. The next morning the TV came on and the flashing stopped. Turned...
Hi, 5 times blink of standby light shows that TV needs White Balance adjustment. No need to dump it, adjustment is also not so difficult. Let me know if you want to give it a try to guide you.
SONY KDP-65WS550 projection or power problems NEED HELP
3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode. got this off a website that had Sony codes listed.
Rusty
http://www.the-tv-dude.typepad.com
5helpful
Sony Wega KDP-57WS655 Standby light blinks 9 times and wont turn
Service Manual of KDP-57WS655 says if TV standby light blinks 9 times then problem is Zero Corssing Detector and you need to replace diodes, D6116 or D6301 which are open on G Board.
15helpful
Model KDP-51WS655 - blinks 9 times
A 9 flash code is defined as a zero cross failure, basically a power supply fault. It is usually caused by the failure of one or two diodes on the G board D6301 or D6116. D6116 is 871908197 and D6301 is 650056721. If you can get them and are handy with a soldering iron, you can probably replace them. Be sure the set is unplugged and use care when installing them, as high voltages exist in the set even after it is unplugged. If this answer is to your liking, please be sure to rate it. Thanks! Also, a good confirmation of this is to turn the set on using the following error code display method. With the original remote, press the following buttons:
DISPLAY
5
VOL -
POWER
The set will usually turn on this way if the diodes have failed
The flashes are a diagnostic. It should be only one flash pattern, either a 5 or a 10 (there are several other patterns in between as well). Please verify the number of flashes after power on, several times, and post back here, and I will be able to help with the fix. Based on your initial description, it my be the HV distribution.
1helpful
Sony KDP-51WS655
how many times does the light blink?
Sont kp-46wt510 blinks 4 times
IC1509 8-759-593-33 IC LA78045 35.98
Q1505 8-729-423-33 TRANSISTOR 2SC3311A-QRSTA
Replacement part
8-729-119-79 TRANSISTOR 2SC2785-FEK-HFE 1.02
these ic locations are different than yours but same part number.
is there a 2sc3311 near by LA78045?
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
