SOURCE: the radio for my 2007 chevy malibu is locked
if you hold the 1 and 4 presets and you get 3 lines like this - - - then that meens there is no code stored so the problem is not in your theftlock but the radio or power to it.
SOURCE: jump start 2000 venture
In order to reach the negative terminal to the battery in a 2000 Vebture (I have one) you must first remove the fuse housing. The fuse housing is a large black box that sits atop the battery. There os a single bolt that holds it in place located in fron of the battery bolted into the lip of the motor bay. Unscrew this, then unhook the fuse housing from the cross bar running from the back roght to the front of the motor bay. This is a tight fit so watch your knuckles. Once the fuse housing is out, the negative terminal is located on the backside of the battery. It is a tight squeeze black is negative, red is positive.
SOURCE: how do you reset power sliding door on 2000 chevy venture
there should be information in your owner manual telling you how to do it if you have miss place your owner manual try this website to see if you can down load one for your car its www.edmunds.com and i hope i was able to help you Michigan Man
SOURCE: 2000 Chevy Venture shows gas gauge as always full..
if the remote works but the switches inside the van doesn't then the most likely fix would be the switch, tthough it is strange that both would quit. the place too start would be pop out the switch with a small screwdriver and disconnect the connector. the top left pin and the top middle pin is the unlock circuit in the switch. check continuity with your multimeter while pressing unlock. if no continuity, then get a small piece of wire and jump those pins in the connector,( the top right and center ) you should hear the doors unlock, then you know for a fact that the switch is bad. the unlock is used more than the lock so it is a more common failure. you can also use a continuity test on the rear wiper switch. though it is more common that the motor would stick from not being used. hope this helps if you have any more questions i am glad to help... dustang
