Question about Tomtom GO 300 GPS Receiver
Threatening shut down
I power up my TomTom Go300, and it keeps flipping back and forth between the map, and the "Shutting Down your TomTom Go300 in 10, 9, 8, 7, etc.. then flipping back to the map.
Back and forth, back and forth.
I tried downloading the latest version, and resetting to the original factory settings. It's still doing it.
It is probably your internal battery and needs replacement. There is a menu function to not shutdown when loss of power (under battery preference, after screen save). If you don't use the battery, try this.
Posted on Jan 29, 2010
6ya staff
SOURCE:
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Toshiba laptop satellite L645D-4040 keeps shutting down
does it shut down and then just start right back up? If it does then press and hold the power button and make sure it shuts down all the way. Then take the battery out and press and hold the power button after the battery is out for about 5 seconds. Then let it sit like 10 - 15 seconds. After that put your battery back in and turn it back on and see if this solved your problem. I think its in a loop to make it keep restarting. Let me know if this helped. Thanks, Herb Stacey
Oct 04, 2013 | Computers & Internet
My blackberry pearl flip which is brand new, Keeps shutting down?
please return the phone and replace it with another....... It's not suppose to be shutting down. It's a brand new according to you.
Don't attempt to repair or disassemble this phone, if you do, the seller won't collect it back.
Just return the phone.....
Regards.
Apr 28, 2011 | Cell Phones
Hi my tomtom 920 keeps shutting down .when programing it has been set not to shut down and allways does it just when you want it most. can you help. regards roger.
It has to be one of two things: bad battery or your charging circuit does not work correctly to charge the battery. We see this all the time. www.nabilselectronics.com
Sep 29, 2010 | Tomtom GO 920 GPS Receiver
My laptop monitor keep shutting down....
Check the display power settings in Control Panel.
Oct 04, 2009 | HP Pavilion dv4000 Notebook
Last week I updated my TomTom One with the latest maps, etc. Since then whenever I use my TomTom it keeps displaying a "Shutting down in 10 seconds" screen, with follow up screens, and then it shuts down....
Make sure you have "never turn off screen" checked, To do this tap "change prferences" tap the forward arrow until you see "battery saving preferences". Tap "battery saving preferences" then tap "never turn screen off". Tap "done" and make sure that "switch off when external power is lost" is not checked. Tap "done". If you do not see this option go back into "change preferences" tap the forward arrow until you see "show menu options" it should read "show fewer munu options"
Sep 26, 2009 | Tomtom One XL GPS Receiver
Tomtom one automatically shuts down after a certain amount of time when connected to computer. i am using a mac and trying to install maps. but keeps shutting off in the middle. but always shuts off...
I am not sure about the mac side but do not do it via a hub do it direct to a USB 2,0 compliant port.
And only use the vable that came with it not just one that fits.
not all cables are equal
Should be i know but its not always the case
If the mac has any power saving options esp for individual bits of hardware (lots of hardware have their own power saving functions) then turn them off windows allows pc users this option.
Aug 22, 2009 | Tomtom ONE 130 GPS Receiver
Charging the Tom Tom - unit shuts off with car charger plugged in
your rechargeable battery inside has a limited life and has to be replaced when this problem happens.
May 28, 2008 | Tomtom GO 510 GPS Receiver
TomTom Home
I had a similar problem when trying to update my dad’s old TomTom Go300. I bought a new map and downloaded TomTom Home 2 (as instructed on the website) but found that the Go300 was recognised by the computer it wasn't recognised by TomTom's own Home 2 software.
To cut a long story short I uninstalled Home 2 and downloaded Home 1 (from http://www.tomtom.com/plus/service.php?ID=17 Home 1 is the one on the right, listed as being the version of Home you use for Navigator 6).
Then when I switched the Go300 on it was recognised by Home1 - although the new map I had bought wasn't listed as being available for download.
However, I updated the Go300 with the available listed free updates, then switched it off.
Downloaded Home 2 again and switched the Go300 on - this time it was recognised by the computer and the new map I had bought was available to download.
So far so good - the only problem was the the postcode search facility was not the same as it had been - I could now only search the first 4 digits of the postcode. There is a fix for this on the tomtom website:
http://www.tomtom.com/support/index.php?Language=1&query=postcode&FID=9852
which I followed and which worked.
Hope this may be of some use to someone! It took me hours to figure it all out. But it's up and running now.
Redd
I read and read and re-read the TomTom website looking for any info that would help but came up with nothing. A few hours later and the air thick with torrents of language I didn’t think I was capable of I discovered that I needed to download Home1 first and let the Go300 connect to the computer via Home1 before it would be recognisable by Home2. Okay…
On the website, though, Home1 is listed as being the version you use if you have TomTom Navigator 6. It’s not even called ‘Home 1′. Confusing eh? Anyway, I downloaded that and from there found that I could get my new map onto my Go300. Once the map and other updates were installed and I had switched the thing off I then found that Home2 recognised it at last.
That had to be one of the most ridiculously long-winded things I’ve had to do on a computer, mainly because TomTom’s confusing advice on their website made the whole process so damn difficult. Perhaps they hoped I’d give up and buy a new one? Tsk.
Redd
May 17, 2008 | Tomtom GO 300 GPS Receiver
Player shutting down after 10 seconds
Shutting down completely like power is gone or just DVD stopping with power on? If completely shutting down the look in power supply and find bad capacitor and replace. If DVD stops with power then look at laser, clean or maybe damaged.
Sep 14, 2007 | Polaroid PDV-1002A Portable DVD Player
Tomtom GO 300 GPS Receiver Logo
124 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
