Error code le on washing machine wm-1480fhd.... drum stops spining in certain directions and then stops with the error code :LE
Well, according to the LG error look up table:
LE
Locked motor error. Cause: The connector (3-pin), male,white) in the motor
harness is not connected to the connector. (3-pin,female,white) of stator
assembly. Or the electrical contact between the connectors. (3-pin,male,white)
in the motor harness and 4-pin,female,white connector in the main PWB assembly
is bad or unstable. Or the motor harness between the stator assembly and main
PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective.
Decoding the techno speak, this means that the little rev counter, built on to the back of the motor and connected by 3 wires has either come loose, fallen off, failed or its wires are unplugged. The result is the machine can't figure what speed the motor is running at, so it shuts it down.
