you need to input a code in order to reset your copier.. im having the same problem i used to have the code but i lost the paper with the code on it.. as soon as i get it i will post =] you need to input a code in order to reset your copier.. im having the same problem i used to have the code but i lost the paper with the code on it.. as soon as i get it i will post =]
You can't post conmments that contain an email address.
Hello Bheesam,
Turn off the power switch, wait about 10 seconds, and
then turn on the switch again. If this does not clear the
message, write down the code (Main code and sub
code exists.) that appears and then unplug the power
cord and contact your authorized service Rep.
Here is a link for you: https://www.manualslib.com/manual/885094/Sharp-Ar-6020.html?page=111#manual
F5 errorContent Copy lamp error Detail Copy lamp voltage detection error Cause Power unit trouble, Copy lamp trouble Inverter trouble, MCU PWB trouble Check and remedy Replace the power unit.Check the copy lamp ON with SIM 5-3. Replace the copy lamp. Replace the inverter. Replace the MCU PWB.
SOLUTION: ERROR MESSAGE U2-40, SHARP COPIER AR-5127 PRESS # PRESS = PRESS C PRESS = TYPE 16 PRESS ENTER BUTTON (the button for making photocopy) PRESS 'OK' TWICE Note: be fast in pressing all the buttons. FROM EKPA ONU - (+2348055790979, NIGERIA,LAGOS)
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
OK, CH normally means the one of the covers(front or side panels) is open or the developer unit is unplugged try these to see if that fixes the problem.
p.s
When the covers are closed a small tab on the covers triger a interlock switch or optical switch.
Hope this helps
