When powered on H4 keeps flashing on the display panel
SOURCE: Sharp H4 Error message
Hello sir; The code need to reset;
1, press "#", "interrupt", "c", "interrupt" keys.
2, enter 14 then press start.
3, if machine work, please don't forget to give me a good rating.
THANK YOU !!!
SOURCE: Toshiba e-studo120 H4 error code
This should do it.
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
SOURCE: sharp al2030 error code h4 upon power up
Here is the solution straight from the lips of tec support at sharp.
This can happen due to a power outage.
Here is how you fix it.
1. Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
2. Once again Hit clear, then auto. (clear is on the right the red C, auto is on the far left)
At this point wait for the screen to go dark.
3. Type in 14 (hit the 10 once an the 1 button 4 times)
4. Hit the Green Button.
The screen will go dark and reset the copier.
SOURCE: how to change the paper size in olivetti copia d 20 w copier
In pallet install to limiters as is done on sectoring, but with inverse, distant sides install the plastic insertions as defined, there there is helps with instruction format.Good luck!
