I reset the settings - after listening to the greeting several times, it starts to cut off earlier and earlier so the whole greeting is not heard. The settings - security, number of rings, time and day, etc., randomly revert back to default settings. When a call is made, the greeting starts to play, but abruptly ends partway through and the machine disconnects and no message is recorded. I tried resetting several times and that just seems to make it worse. FYI, it is connected to the cordless phone - I have had other answering machines attached to a cordless phone so cannot see why would be the problem, but thought I should mention that. Thanks.
SOURCE: Answering drops call when answering
I have had the same problem when trying to connect the GE-29569 to my PBX. The PBX manufacturer suggested the the answering machine might be pulling too much power, which would result in a dropped call. I have not resolved this problem yet. However, the machine works fine when connected to my home line, but still does not work with the PBX. Since both work fine separately, I can only assume that power requirement might be the problem. RFR-US
SOURCE: phone rings many times with no answering message coming on and no messages recorded
I can't seem to get the security code entered. It won't change. None of the numbers will change when I try to set it up.
SOURCE: howto change ring times for audiovox answer machine
how can I set the proper day and time on my answering machine same as above Audiovox AXT847
SOURCE: how to set the time, and longer than 5 rings to my digital
it answers the call after 2 rings, how do i get it to wait 5 rings
SOURCE: machine will not answer to take a message
You can download the manual at
http://www.home-electronics.net/ge/pc/IB/28112EE2_IB.pdf
