How do i reset the bios password?
On the u400 the shorting blocks are labelled G1 as in the attached photo
5years late is what?
To clear the CMOS, you must remove the battery from your laptop and
leave it out for at least 30 minutes to an hour. The way to remove the
battery from your Toshiba will largely depend on the model. A common way
to remove the battery--particularly with newer models--is to release
the battery lock on the bottom of the laptop, while sliding the
accompanying tab over to the side. This will pop the battery out from
its tray so that you can then pull it out all of the way out.
Before you remove the battery, turn off the laptop and remove the AC
adapter. Otherwise, you could end up harming yourself or the laptop
components. You must also ground yourself to prevent damaging the laptop
with static electricity.
After about a half an hour or more, return the battery back to its tray and lock it into place. Power on the laptop. The computer, ideally, should no longer ask you for a BIOS password.
It's important to keep in mind that resetting the CMOS means that all
of your BIOS settings will be reset to factory default. Also, sometimes
you may need to leave out the battery for much longer than an hour to
reset the password.
SOURCE: toshiba satellite pro 6100 bios reset?
The Password can be removed via the printer port
What you need is a password removal tool, It removes the Bios and start-up passwords.
It costs about £5.00. Easy to build but it costs more to put the kit together.
I think you were quite hard on the assistance.
People here are just trying to help. At least appreciate that!
SOURCE: BIOS Resetting...
Please open this link this will help you
http://www.thenetworkadministrator.com/biospasswords.htm
And dont forget to rate FIXYA if it didnt help please reply but dont rate any rating
Thanks
Regards
SOURCE: how to remove bios password for Toshiba Satellite A200
If you know the current password, use it to enter BIOS SETUP.
Then, type a "blank" ("space-bar") as the "new" password.
If you don't know the current password, you're stuck;
this is a "security" feature to prevent a stolen laptop from being used by the thief.
SOURCE: toshiba satellite pro l 350 bios password reset
This is the ONLY other way, save paying Toshiba and filling in proof of ownership forms.
The BIOS password is removed by the BIOS configuration, you need the BIOS password to get into the BIOS configuration.But if you do not have the BIOS password then you need to construct this dongle device.
TOSHIBA BIOS PASSWORD DONGLE
You can build a dongle that plugs into the printer port.Purchase a 25 pin male D sub connector and solder insulated wires to the various pins as listed below. The pins are numbered on the connector
http://www.tilman.de/sonstiges/toshiba/dongle1.jpg this is a picture of the finished dongle
Wire the pins as follows :-1-5-10, 2-11, 3-17, 4-12, 6-16, 7-13, 8-14, 9-15
Plug the finished dongle in the printer port and power up the laptop. The password will be reset, go into the BIOS configuration to check the BIOS password, you may have to disable the BIOS password.
SOURCE: I need to clear he bios password in a toshiba
Good luck, Bowling Crony.
