SOURCE: Bean hopper is full, grinder is grinding...but NO COFFEE!
Sometimes the chamber between the grinder and brewer will clog up. Try: Open the grind all the way up to the highest number. Push the grind button and while grinding move the dose knob (the one with the + - sign toward minus. If it does not kick in and dose try it again. If it does take off then leave it on the high number for 3 coffees. Then while the grinder is turning move the two knobs back to whre they were. If this does not work you can reomve the brew unit and right above where it sits in the machine there is a trap door that you can open. Open it and shove someting like a straw up toward the grinder and you should get a bunch of grounds droppiing down. Then try the above procedure a couple more times. If this does not work you may need to google "Saeco repair" and send it to an authorized repair center.
SOURCE: No coffee brewing with beans, but with coffee brewing with ground coffee.
It is possible that the grinds chute is blocked, remove the brew unit and check the chute from the grinder chamber, make sure that it is not blocked with coffee grounds.
SOURCE: The burr grinder grinds and
For smitty_2007 you may have to also clean the grinder. Instructions should be in the manual. Remember when doing so there is a slot on sode where grinder goes that the coffee pushes out. Sometimes that will get packed and need to clean also.
SOURCE: Saeco talea touch - grinds & brews coffee into grounds drawer??
Try this, adjust the grind to a coarser setting atleast 2 numbers, then remove brew unit and look behind at white plastic valve, there is a small chamber under valve make sure chamber is clean and that the small discharge from chamber to drain tray is also clear. Then remove shower screen from brew unit and clean if necessary, also check the tube from the shower. Reinsert and test.
SOURCE: Hello. I have a saeco vienna superautomatic
This happens due to condensation caused by steam developed at the end
of the grinding cycle. Make sure that the grinding chamber is
completely cleaned and dried before using the grinder.
