Question about Quinny BUZZ 3 Jogger
Code cassette chevrolet spark - Quinny BUZZ 3 Jogger
  • Quinny Master
  • 1,637 Answers
Hi
If you have a problem with your Quinny Buzz please let us know what the problem is so that we can help.
Posted on Mar 15, 2013
WHERE ARE THE SPARK PLUGS LOCATED IN A 2004 CHEVY MALIBU
Thanks, Glad I can try, however, its very easy to locate. if there's a plastic trim/cover over the engine remove-it and set aside. The Spark Plugs is sitting right below the Ignition Cassette or Coil as it is also referred to, it may say ECOTEC on the cover, secondly, remove the electrical harness on right side of the cassette, it's just above the oil filler cap, then remove the four, 10 bolts and pull-up the Ignition cassette. All four Spark Plugs will be there for easy removal and replacement. Reverse actions will be in order... Here is what you will need to perform the repair: 3/8 in ratchet, 5/8 in Spark-plug Socket, 3/8 in extension 12 ins long and a #10 socket. For your 2004 Chevrolet Malibu with a 2.2 liter ECOTEC Engine. Hope this DIY was helpful!
Jul 04, 2014 | 2004 Chevrolet Malibu
Saab.93.wont.start
Sounds like DI cassette or spark plug fault. You need to connect a fault code reader to confirm
Jun 09, 2014 | 2004 Saab 9-3
I want the unlock code of radio cassette of car chevrolet spark model 2008
please go to www.autoelectronico.com translate the website with your browser and fix it.
God bless you
Nov 24, 2013 | Car Audio & Video
How to replace spark plugs on a 2000 Oldsmobile Intrigue
On the 3.5 liter v-6, they are in two spots that have plugs. The first three are in the front of the engine. The second three in the back. They are under what is called the"ignition coil cassette". Right in front of the cover that says 3.5 liter is a piece that is about 4-5 inces wide with another piece on top of it about 2-3 inces wide. On the right of this piece you will find some wires plugging into it. The 3.5 liter does not have actual spark plug wires. The wires goto this cassette and this cassette lays on top of the spark plugs. There are seven screws to this cassette, four on top and three on bottom. Once you figure out the front, you will find the back set. However the back are a terror to get to. I had to replace all of the back plugs by feel
Oct 10, 2012 | 2000 Oldsmobile Intrigue
I have a 1997 honda accord radio (with a cassette player and I lost the code card
You need to contact a Honda dealer and provide your VIN# to get security code for your radio
Mar 15, 2011 | 1999 Chevrolet Venture
Where do i locate the spark plugs
the spark plugs are under what is called coil cassettes-the vue does not have spark plug wires or an ignition module-instead there are cassettes that sit on top of the cylinder heads which have individual "coil on plugs" for each cylinder
Sep 11, 2010 | 2003 Saturn VUE
Spark plugs 2000 cad dts, where are they? how hard to do?
Spark Plugs are Located UNDER COIL Packs
1. Remove the ignition coil cassettes.
2. Remove the spark plug boots. NOTE: Refer to 3. Clean Spark Plug Recess Notice in Service Precautions.
  1. Remove the spark plugs from the cylinder heads.
INSTALLATION PROCEDURE
  1. Measure and adjust the gap of the spark plugs. Refer to Spark Plug Usage. NOTE: Refer to Component Fastener Tightening Notice in Service Precautions.
  2. Install the spark plugs into the cylinder heads. Tighten Tighten the spark plugs to 20 N.m (15 lb ft).
  3. Install the spark plug boots onto the coil cassettes. Ensure that the boots are fully seated against the cassette.
  4. Install the ignition coil cassettes.
Feb 21, 2009 | 2000 Cadillac DeVille
Panafax uf-790 - info code = 011
Check cassette refers to the paper cassette. If there is no paper or the cassette is not seated correctly, then you will get that error. If you tried those, then check the left rear of the cassette for a tab. If that tab is broken off you will get this error and you need a new paper cassette. Good luck.
Jun 14, 2008 | Panasonic Panafax UF-790 Plain Paper Laser...
Quinny BUZZ 3 Jogger Logo
102 people viewed this question
Top Quinny Baby Gear Experts
ray gallant
doobuster
Tom Chichester
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
