Question about HP DeskJet 6122 InkJet Printer
Trying to print multiple copies and only one copy prints
Printer type: HP 6122 Inkjet color.
OS on PC is Vista
When I am using MS Works I go to File\Print\change the number of copies to 10 and then hit the print button. Only one copy comes from the printer.
I have rebooted printer and computer and still just one copy.
Please help.
Thanks
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 20 Answers
The setting of quick print is as same as print. So you should check the print settings.
Click File->Print, in Copies Textbox, enter the number of copies.
Hope that help
Posted on Nov 05, 2017
6ya staff
SOURCE:
ravi chavan
  • 238 Answers
SOURCE: computer doesn't print color
Hi, the problem seems with the logic board inside the printer, are you in a position to open the printer and try some stunts, that is only if you have done it earlier.. let me know??
Posted on Dec 17, 2007
freetek
Steve Allison
  • 5569 Answers
SOURCE: My hp 1320 prints only one copy
Windows may have eaten its baby again- that is, the driver for that printer.
Open the Control Panel, then Printers and Faxes, delete any listing for that model of printer, make sure the printer is on and connected, then reboot your system. This will force Win to 'find' the printer and install an uncorrupted driver for it.
(=Plug and Pray)
Posted on Sep 23, 2008
Anonymous
SOURCE: scanning multiple copies
The trick is to put the scanner in PROFESSIONAL MODE !!!!! Select that option in the top right corner of the Epson Scan application when it first opens up.
http://files.support.epson.com/htmldocs/gt25__/gt25__ug/projs_1.htm
Posted on Dec 10, 2008
Anonymous
SOURCE: unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
How to turn off test print on a HP DJ 6122.
Yes.Tell it to print a dot short word and when it starts printing unplug the power cord so it stops with the printhead somewhere to the left. Then do your cart change. It won' t know you did anything.
The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Feb 06, 2014 | HP Deskjet 5940 Photo InkJet Printer
Do I have to have a color cartridge in order to print? Can I just use a black ink cartridge?
The HP DeskJet 6122 can print with both or only one ink cartridge installed. The printer driver includes an option to print in gray scale as a substitution for color. If you choose to print a document that has a color other than black and white with only a black cartridge installed, I recommend you select the gray scale print option. To select gray scale, select the printer properties and check the box for gray scale rather than color printing. This selection can be made either at the time a document is ready to print (ie., a one time selection, using the "Properties" box in the print options window), OR as a permenant setting using the Control Panel, Printers, HP DeskJet 6122, "Properties" window. Once changed in the general printer properties, these settings remain active anytime the HP DeskJet 6122 printer is selected to print a document.
Sep 03, 2013 | HP DeskJet 6122 InkJet Printer
My HP C6380 won't print multiple copies of a page even though I select how many copies I want of the page . I have to keep printing each page individually which is very time consuming.
what is he OS ?........what connection USB/wireless ?..........From what application you are printing? ..........have you checked the printer printing properties and ticked of the collate check box where you have selected mutiple pages ?.....
Jul 15, 2010 | HP Photosmart C6380 All-In-One InkJet...
Will not do mult copies zsweed@comcast.net
WHAT EXACTLY ARE YOU TRYING TO PRINT ???
IF YOU ARE TRYING TO PRINT SOMETHING FROM MS OFFICE WORD OR A PDF FILE
THEN .. OPEN THE FILE THAT YOU WANT TO PRINT
NOW ON THE TOP YOU WILL GET OPTIONS LIKE FILE, EDIT, VIEW, FAVOURITES, TOOLS AND HELP
( IT YOU DONOT GET THESE OPTIONS TAP THE "ALT" KEY ON THE KEYBOARD )
NOW CLICK ON FILE AND CLICK ON PRINT
NOW YOU WILL GET THE OPTION OF " NUMBER OF COPIES " PUT THE NO OF COPIES THAT YOU WANT
NOW CICK ON PRINT ON THE BOTTOM
IT WILL GIVE YOU MULTIPLE COPIES
ALL THE BEST !!!!!
Mar 25, 2010 | HP DeskJet F4280 All In One Printer InkJet
Im trying to get it to print copies only blanks so far
You can make multiple copies by loading them print side up into the upper feeder you'd use to fax, then entering the number of copies on the keypad and hitt the copy button for color or black
or you may lift up the carriage and place a page on the scanner glass, close the carriage select the number of copies and hit the copy button for color or black
Oct 30, 2009 | HP OfficeJet 7410 All-In-One InkJet...
Can i install the HP Deskjet 6122 on a brandnew HP Laptop with vista OS?
"Add a printer" in "My Computer"/"Printers" or "Control Panel"/"Printers". The 6122 will print from the HP 920, 930, 932, 940 & 950 drivers also - (which are included with your Windows XP and Vista systems). If you chose the 970 driver it will want a second sheet of paper to print a test page, which you can ignore and it will stop trying. All drivers seem to be the same print quality in my systems. I do not use the 970 or 6122 driver at all so I don't have an ink level monitor or any possible related potential glitch. I wet and slap stubborn old ink cartridges to un-stick dry jets. sometimes I use a small clear silicone tube to suck a bit of ink to get them started as the jet holes need priming sometimes if they are old.
Oct 10, 2009 | HP DeskJet 6122 InkJet Printer
I'm not sure if this is a printer driver problem or a network problem. I have 3 computers networked (1 Vista, 2 XP)all using a CP1700 through a jetdirect print server. The vista computer works more or less...
So your printing to a network IP port? I don't this the setup is the problem if the computers see this printer as a network printer. I believe this to be a driver problem. I would try either a 5e or genric driver of some type. I'm not sure what type of printer this is so...
Sep 29, 2009 | HP cp1700 Color Inkjet Printer
Can't print multiple copies from Dell Inspiron 1525 with Vista
hi
its most prob a driver problem, thats the trouble with vista if you have installed the cd driver disk that came with it,
its most prob only for xp it will run on vista but not all features will work go to hp web page click on the drivers and software location, then put in model number of printer then next it will give you diff. windows drivers and pick the vista one that with your pc/laptop but please un-install the software you are using first the shut down and restart..
then install the new drivers etc this should sort out your problem.
if still having problems please get back to me .. matdav69
Apr 05, 2009 | Lexmark X5470 All-In-One InkJet Printer
On your Brother's drop- down menu, left click on PRINTING PREFERENCES . On the BASIC tab, choose the number of prints in the COPIES box, then left click on APPLY. If that does not work, go into PROPERTIES, left click on the SECURITY tab, and check that you have authorization to run multiple prints. Also, check your PRINT SPOOLING mode to make sure it is activated, and check authorizations in OFFICE 2007- it may be set to restrict multiple color pints.
Aug 29, 2008 | Brother MFC 420CN All-In-One InkJet...
HP DeskJet 6122 InkJet Printer Logo
59 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
