Question about HP LaserJet P2015dn Printer
Ink rubs off or prints double/messy
I printed a bunch of labels and some pages all the ink rubs off. On later pages, only the labels at the bottom of the page does the ink rub off. The labels at the top of the page seem okay... or at least better than the bottom ones.
Then I tried printing a text page from Word and I got double the text, offset by a few inches and neither set of words was clear. Also, the ink does stay on the page either.
I just bought this printer a couple months ago!
HP LaserJet P2015dn
  • gwennoda Mar 12, 2009
    I called tech support at HP (800) 474-6836.
    can only use 43 lb paper weight maximum
    otherwise the paper is too thick and the printer can't heat up enough to set the toner.
    for printing on labels (so the ink doesn't rub off):
    In MS Word
    go to File:
    Print
    then Properties
    click
    on tab Paper/Quality
    Paper Type is: (drop down
    menu)
    "Heavy 90-105 g/m2"
    (can also use "Labels", but
    might not get quite hot enough)
  • 788 Answers
Sounds like your fuser is getting ready to stop working. Your fuser creates the heat so the toner from the cartridge is baked onto the paper as it passes through, your toner is rubbing off, so you could try cleaning, but I'm sure it'll be a new fuser, or possibly a fuser roller. Your owners manual has all the information and step by step trouble shooting guide to let you know.
Posted on May 23, 2017
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 8 Answers
SOURCE: printer prints double sided only even though set for single
This is cause duplex printing option is enabled in the driver. If you have win XP, go to control panel and then printers & faxes.
Right click on your LJ P2015 printer driver and click on properties.
Click on the tab 'Advanced' and then click Printing Defaults.
Remove the check mark for 'Print on both sides' under the 'Finishing' tab.
Click Ok and Ok again.
Posted on Nov 24, 2008
jonb3838
John Cole
  • 237 Answers
SOURCE: Hp Laserjet 1320 toner rubs off page
when the toner rubs off means it wasnt fused which means you need to replace the fuser
Posted on Feb 27, 2009
Anonymous
SOURCE: Ink is smudging on paper
Try replacing the fuser bulb located inside the fuser roller. This is accessible from the back of the printer. Remove the plastic piece on the back, unplug the two wire connections to the fuser, remove the toner wiper on top, and then remove the fuser. On one side of the fuser, you'll have a protruded plastic piece with two screws in it. Remove that piece and you'll see one more very tiny screw on top and another regular sized screw on bottom. Remove those both and the plastic piece. Inside you'll find the fuser bulb.
Posted on Apr 09, 2009
PrintDocta
  • 217 Answers
SOURCE: HP 1600 Colour laserjet Double image
Colour registration problem (some printer loose their registration from time to time).
There will be an option somewhere in the menu system of the printer, or the HP 'Toolbox' to correct this.
Posted on Aug 30, 2009
Why does hp officejet Pro 8600 crashes when printing avery labels?
Avery labels may be blocked on your computer so check your security settings. Other wise you may need to refresh the page, your computer or the printer. If that doesn't help you may need to double check your ink cartridges are full and correctly placed, also that the wires connecting the printer to your computer are all in properly.
Mar 01, 2014 | HP OfficeJet Pro K8600 Printer
Streaky lines through photographs when printing
remove the ink cartrages and clean the connections and print heads with rubbing alcohol on a qtip. this will be messy. let dry for a few minutes and reinstall the cartridges. also streaks can be caused by low ink.
Mar 07, 2011 | Brother MFC 210C All-In-One InkJet Printer
Printer leaves gray ink on page
I guess that you use a non-genuine print cartridges, try to use a genuine one.
please confirm me at walid_sayed@hotmail.com
thanks
Apr 03, 2010 | HP DeskJet F380 All-In-One Printer
Printing labels from ebay but they come out blank
If you got a blank shipping label, kindly double check first the ink of your printer. Then you can go ahead and reprint the shipping label. Please follow these steps :to reprint your label:
1. Log in to PayPal at:
https://www.paypal.com/.
2. Click the "History" link.
3. Find the transaction you want to print the label for.
4. Click the "Details" link for that item.
5. Click the "Reprint Label" link at the bottom of the page.
Feb 04, 2010 | Dymo LabelWriter 400 Thermal Printer
On anything other than plain printer paper, the ink tends to rub off the printed page - really a problem with labels and envelopes. I have tried changing the printer settings for these items, but it does...
You may need a shop to increase the fuser temperature. You also may just need a new fuser. In printing preferences you need to make sure you're telling the printer you're using envelopes or labels. When the toner rubs off, the fuser is just not hot enough.
Nov 05, 2009 | HP LaserJet P2015 Printer
Printing but blank pages coming out .
Take the ink cartridge out of the printer. On the bottom of the cartridge, there's a copper/gold surface with bumps and holes. Take a napkin or peice of paper and rub it on this surface. This serves two purposes - if there's any dried ink or blockage, it will help clean it, and it's a test to see if there's any ink left in the cartridge. On a normal ink cartridge, rubbing paper on the bottom would cause some ink to smear onto the paper. If nothing wet comes out, the ink cartridge is dried out or empty. You'll need to replace it.
May 19, 2009 | ASUS Intel 810E Chipset CUWE-RM...
Rp 3100 Drum Problem
You can clean it, thats a good idea but,,(and this is messy) roll back the master.. take out the ink cartridge, use a rod to squeeze some ink onto the area, and smooth it out into the screen with a plastic scraper.. Lay the master back over. Keep scrap paper around and print a big black square and run a couple hundred sheets through.. This will work. Messy but will work. If you don't want to manually put some ink on the area.. Print a large black square and run a couple hundred sheets.. see what that does.
Sep 10, 2008 | Riso RZ220 Duplicator
Lexmark 125 Prints Labels with color cartridge
I kicked the **** out of it and it started to print. I don't recommend it if you are afraid you may damage the electronics. The way I saw I spent damn near 70 dollars on some useless print cartidges nothing was wrong with them. The error message kept saying ADD CARTRIDGES. Anyway I'm thinking about a new printer anyhow.
Aug 28, 2008 | Lexmark X125 All-In-One InkJet Printer
MP730 printer Canon
Warning: This can be messy. Covering your counter or table and wearing thow away plastic gloves is strongly recommended. Take all the ink cartridges out. Wipe the rims of the ink ports and seal with tape or peel & stick label, to stop them from drying out and set aside. Flip up the plastic lever on the right side of the ink cartridge holder box. This will release the hold down mechanism that keeps the print head in solid contact with the electrical contacts at the back of the ink cartridge holder. Gently lift out the actual print head. You may have to gently use a straightened out paper clip to rock it out so you can get it with your fingers. Get a small plastic tub (cottage cheese or yogourt container) etc., and soak it in rubbing alcohol for an hour or two. Put enough over it to also soak the ink screens on the other side from the printing part of the head. Clean gently with a Q-tip and alcohol. Inspect the bottom side with a magnifying glass if available, and get any dried ink off. Change the alcohol and do this again until all ink is gone. Finally, shake the alcohol out over a newspaper (watch, i'ts messy) and leave overnight to dry. Clean the gold dots with alcohol just before you put it back in. It is important not to touch the gold or the actual printing part of the print head. Put it all back together and run a few head cleanings thin a nozzle check. If the problem persists, call Canon and order a new print head. Approx. $60-70. Good luck.
Dec 26, 2007 | Canon MultiPASS MP730 All-In-One InkJet...
Printing on Stationary with an HP Laser Jet 1320
Most printers and copiers are made for the standard 20# paper, if using a different paper then most of the time you need to specify what type ie: transparency, labels, lbs etc. so the machine can accommodate itself. ( lowering or increasing the heat in the fusing section, and pressure on the paper.)
for that machine everything is done through the pc. go to File, Print, right click on the printer, go to properties got to device settings, General, printing preferences and paper quality, there is a box there for paper options. try setting it to cardstock.
Oct 04, 2007 | HP LaserJet 1320n Printer
HP LaserJet P2015dn Printer Logo
5,491 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
