Can you tell me where USB port is located in HP pavilion MX75
I just bought an MP3 player and it requires to be charged and down load music on a computer. I own an hp pavilion mx75. I am technically challenged so please use laymen terms. And your telephone number may be helpful.
Can you tell me if there is an USB port and where is it located in HP pavilion MX75?
Re: Can you tell me where USB port is located in HP...
USB ports are located on the back and also on the front on newer desktop PCs. These are on the computer tower - not the monitor as your posting is categorized. They are rectangular slots with four copper contacts inside.
MP3 players can only play music files in mp3 file format.You can download mp3 music files from the Internet toyour computer and then copy them to your MP3 player.For your CD collection, you need to convert your CDs tomp3 music files onto your computer or download them from the Internet and thencopy them to your MP3 player after you have connected the USB cable tothe MP3 player and the computer. You can do this using Windows Media player and Rip the CDs - Media Player willcreate a MP3 music file for each music track.Click on this link for instruction on converting musicfiles to mp3 file format :- http://www.fixya.com/support/r5798418-creating_transferring_mp3_music_files
You should not require software for this. The main things are... 1. That your player is formatted to FAT32 2. Your USB ports are working. That is, other devices work when plugged into them. 3. your connection cable is ok and not damaged. 4. The player battery is fully charged
If all this is ok, you should be able to download your songs.Get back if no success.
Connect your player to your PC USB port using the cable supplied and turn the player on. If the cable is ok and the USB port is working, the player will appear as a removable drive in "My Computer" Copy the mp3 songs you want to upload and paste them into this removable drive.
are you charging with your computer through the USB cord or did you get an adapter to charge via an outlet?
If charging with your computer, it could be a bad USB port, try the ports in the back of the tower if your using the front and vice versa.
Is the device responsive otherwise? Can you load music and the like while the device is connected? If not your USB Cord could be faulty and need to be replaced.
If you are using a laptop keep in mind that sometimes the amount of voltage required for this device does not always reach the USB ports. Try disengaging the laptop battery for an hour and then reconnecting it.
here are two methods for loading that model i know they're long but they will work either one will do whatever you prefer :)
**Drag and Drop** Connect your MP3 player to the computer. Some MP3 players connect directly to a USB port, while others connect to a USB port by way of a specific USB connector that comes with the MP3 player. Open the folder on the computer that contains the music files you want to transfer. This is usually the "My Music" folder, available from the "Start" menu, but it can be any folder where you save your music files. Scroll down to the song you want to transfer to the MP3 player. Right-click on the title. When the options are displayed, click on "Send To." Scroll down the "Send To" options and select your MP3 player. This can be listed as your MP3 player's name or as "Removable Drive." Click on this selection. Continue this process until you have transferred all songs that you want to your MP3 player. --**Windows Media Player**-- If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
You may try connecting the Walkman to different functional USB port on the Computer or different Computers. Press and hold the Reset button for 30 seconds then try charging it. If the issue persists then you may try using a different USB cable. If the player doesn't charge even after using a replacement USB cable then service will be required.
ok you need to unplug the mp3 from usb port and then shutdown your computer properly then wen it is totally shut down turn it off at the wall and then back on the same thing happens with me you properbly just didnt shut your comp down properly last time you used it
What happens when you plug it into a USB port in your computer?
It should appear as another drive on my computer. If you already have music loaded up in your hard drive, you could try it one of two ways.
1) copy the MP3 songs from the hard drive and paste them to the drive letter assigned to the MP3 player
2) Run Windows media player. See if your device appears on the right side of the screen. If it does you can simply drag and drop your music into the right side of the screen. It will tell you on the screen.
I have a Dell Inspiron 1501 Laptop and just purchased the TH1101 Flash mp3 player. The install disc will not let me install, it refers me to Windows 2000 home page but where do I do from there. I have Yahoo! Music Jukebox can I just plug into usb port, even though the guide suggests not to.
you need to put the cd in and then you need to wait for some type of loading process and when its done loading you go to the start button on the main menu and then go to the box that says my computer and the picture or the name of the disk will be there and click on it then it will load then it will begin to play or do whatever it does
