Question about Sennheiser HDR 120 Consumer Headphones
Can only hear certain functions
Have a home theatre setup with a Pioneer receiver, Foxtel, set top box and dvd player. When using my TR120 headphones I can only hear sound when tuned into Foxtel and Radio. Cannot hear sound from dvd player or tv via stb. The headphones are plugged into Pioneer receiver. Sound works through all the speakers but cannot be heard via headphones.
6ya staff
SOURCE:
Anonymous
  • 20 Answers
SOURCE: No sound from the TV when the headphones are plugged in.
if you have a stereo unit(am+fm reciever) that has output to speakers, connect the out jack of the tv to input on back of stereo unit(aux in or cd input) then you can have output to headphone and speakers also.
Posted on Apr 07, 2009
Anonymous
SOURCE: Sennheiser Wireless Headphone Stops transmitting signal
I had the same problem when I plugged it into a new HDTV. The problem was that the sound on the TV was set too low. The transmitter has a feature that automatically turns off when the signal is off or too low. Try turning up the TV volume to a high/higher level and it should solve your problem. Using the headphone jack with the white input allows you to use the headphones while bypassing the TV speakers.
Posted on May 02, 2009
Michial Gueffroy
  • 1140 Answers
SOURCE: Do I have any options to get 'audio out' instead of h/p jack?
Try the Audio 1 rear. With the headphones plugged in on some T.V.s the headphone jack unfortunately disconnects the audio from the other outputs. Try looking in the documentation to see if you can change this in the T.V.s menu as some allow you to use both for hearing impaired people. Hope this helps.,
Posted on Jul 10, 2009
suever
  • 46 Answers
SOURCE: My television does not have
You cannot hear the audio from the DVD player because your headphones are connected directly into the cable box. I'm assuming that your DVD does not route through your cable box, thus the audio has no way of getting to your RS 110's. Also, changing the channel on the TV has no effect on the cable box, thus it won't alter than audio.
What you need to do:
  1. Look on the cable box to see if there is an option for AUDIO in (should be a pair of red and white RCA plugs)
  2. You want to run an RCA cable from the AUDIO OUT of the DVD player to the AUDIO IN of the cable box
  3. Then select the Auxillary input from the cable box and you should be able to hear the DVD
Alternatively you can run both DVD audio and video through the cable box
  1. Look for DVD IN on the cable box
  2. Connect the audio/video cables from the DVD player to the cable box
  3. To watch a DVD, switch to the DVD input on the cable box
Alternatively you can run the cable box through the DVD player
  1. There may be inputs for AUDIO and VIDEO in on the back of the DVD player
  2. You want to connect the outputs of the Cable box into the back of the DVD player
  3. You can then select the input on the DVD player to control whether you see/hear the cable or DVD
Posted on Mar 08, 2011
ALGIS SALYS
  • 100 Answers
SOURCE: i am attempting to use my sennheiser rs 110
What are you plugging your 2 RCA connectors (from the headphones) into on the television?
You are correct, usually:
White = Left Red = Right
In this case
Black = Left Red = Right
Not sure....guess some manufacturers need to be different...
Back to the issue,
You to need to connect the Black to White and Red to Red to the TV BUT you need to make sure you are connecting to an OUTPUT and not to an INPUT on the TV. Most newer TV's do have an "audio out RCA jacks" on the TV but not all. It should be labeled at the connector if it is an output, or just another input. You can always consult the TV manual to be sure.
Few things you can do to test
  • Does your TV have a "headphone jack", use the adapter (2 RCA female - 3.5mm connector) to plug into the headphone jack and see if there is sound
  • Connect the Black and Red RCAs from the headphones directly to the another output, like a DVD player, CD Player etc....
I hope this helps,
Magoo
Posted on Mar 10, 2011
Remote codes for XV-HTD520
PDF]XV-BP1 Blu-ray Disc Player INSTRUCTIONS - JVC
resources.jvc.com/Resources/00/01/15/LVT2007-001B.pdf
Check the specification page of this owner's manual to be .... "BD-LIVE" logo is a trademark of Blu-ray Disc .... Some AVCHD discs use the "x.v.Color" format.
Home Electronics Custom Install ' Pioneer Electronics USA
www.pioneerelectronics.com/.../Home-Entertainmen...
Pioneer CorporationProducts from SATA and USB Blu-ray and DVD burners, to on-ear or earbud headphones and USB powered computer speakers. ... Pioneer Receivers, Elite Receivers, Blu-ray Players, DVDs and Speakers. ... Universal Remote Control Files.
Panasonic Product Support - DMP-BD87
shop.panasonic.com > Get Support
PanasonicSmart Network Blu-Ray Disc™ Player DMP-BD87. Details ... Blu-ray Remote Controls.... The remote control for my Panasonic device is no longer functioning.
Jvc xv bp1 blu ray player region free dvd hack - Vaino ...
Dec 21, 2015 | Televison & Video
My Pioneer XV-DV282AP home theatre has no Audio output. Every time I put the volume up/down, it keeps on saying HDMI/TV Audio. It only works with an HDMI cable using the speaker from the Television.
The system is set up to output sound through HDMI to the TV. You can change the setting so the sound is sent to the speakers. The process for changing the HDMI output setting is in page 41 of the manual. You want to choose the AMPsetting. I have included a link to the manual and copied the text below.
1. Press SHIFT+SETUP.
2. Use ?/? to select HDMI SET then press
ENTER.
3. Use ?/? to choose HDMI MODE then
press ENTER.
4. Use ?/? to choose the setting you want
then press ENTER.
• AMP - Output Audio sound of the DVD/CD
and USB function signal from this system
• TV - Output Audio sound of the DVD/CD
and USB function signal from a TV or flat
screen TV.
http://www.manualslib.com/manual/130342/Pioneer-S-Dv180.html?page=41#manual
Jun 10, 2015 | Pioneer Audio Players & Recorders
Sound issue through Home theatre when pulling up applications
Smart TV's make up the audio output for your smart tv apps. You will need to use the Optical output of the TV and plug it into an available Optical input to the home theater receiver. Make note of the name of the input on the home theater receiver (i.e. CD/DVD, TV, DVD, etc) because that is the input you'll have to select on the receiver to hear the App audio. Hope that helps
Dec 03, 2014 | home Audio Players & Recorders
No sound through home theatre with blu ray connected
Make sure that your receiver says optical 1 or 2 on the front display.
Nov 21, 2009 | LG BD370 BLU RAY PLAYER
Installing a pioneer home theatre dvd/speaker system.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
Jul 25, 2009 | Pioneer 45X4 DFS BLUE LED CAR CD
Wiring problems
Not certain if HDMI can be used in a setup like this. I'd try it from the home theater (HT) to the TV, and other wiring for the other components.
For video:
All of these should have component connections (Y/Pr/Pb). You'll only need the video cables for each device:
  • Video out from cable, HT, and combo player.
  • Video in to TV. Your choice of inputs.
For audio:
Hopefully, the two output devices (the combo player and the cable box) have digital audio (fiber optic, or RCA coaxial). Otherwise, you'll only get stereo sound. VHS is stereo only anyway.
  • Audio out from cable box and combo player.
  • Audio in to HT.
The TV won't have anything to do with audio in this setup. Alternatively, you could try hooking up all inputs to the TV, and connecting audio out from the TV to the HT. Works best if this connection is digital, for surround.
Jan 01, 2009 | Sony BRAVIA DAVHDX275 Theater System
Hooking Up The Theatre System to the TV and Cable.
this means you likeley have your cable box connected correctly, if you have it connected to a standard definition input (AV in or coaxial) make sure the that the dvd player is not in progressive mode.
Jan 27, 2008 | Panasonic SC-HT680 System
Sennheiser HDR 120 Consumer Headphones Logo
Top Sennheiser Audio Players & Recorders Experts
Michial Gueffroy
Rob Beech
Geoff
Are you a Sennheiser Audio Player and Recorder Expert? Answer questions, earn points and help others
