I know it is not a C1U microphone. I have a Microphone cable - and I know I need a phantom power supply - but will the power supply then connect to the computer or do I need more cables/connection /USB interface...or have I got the wrong microphone? Thanks
SOURCE: my behringer c1u doesn't have
Answer from official Behringer support:
The green LED is fine. The newer units have green LEDs.
Please download and install asio 4 all from:
http://www.behringer.com/EN/Products/C-1U.aspx
We hope that we have been able to help you with this information.
SOURCE: Hi. I bought a Behringer
the type of mic input built into a pc (with a mini-jack socket) will not accept the output of a pro dynamic mic such as the one you have - it won't work correctly. You require a pre-amp or mixer - or what would be better for you would be an audio interface with a built in pre-amp such as this:
interface example.
Testimonial: "Thank you!!"
SOURCE: I have a mic Behringer
You can't do that, the C-1U is an usb mic, so you can only connect it through an usb cable, if you want to use it with the m-audio interface, you need to get a normal C-1 or any other mic with XLR connector.
