First thing to do is unplug it for 5 minutes then plug it back in and see if the cpu reset.
How about a model #? please. on the door edge or inside edge. sometimes behind the kick plate.
hope this helps.
You need to research the code along with the model at Frigidaire website.....if you cant find the answer you should contact the Frigidaire tech support people.
Typically, your dishwasher can be reset by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn your dishwasher on. Confirm that the door is securely latched and then select a cycle. Dishwasher should resume normal operations. I hope this information helps to some degree.
Hope this helps!
The steam has gotten into the keypad display and fried it. Call Fridgidaire and let them know you've seen numerous people on the internet with the same problem and that you need part# 154554401 It worked for me.
a common place to leak on these machines is through the heater leads. run the machine w/lower panel off and see where its coming from , if its dripping down the heater leads, chances are the 2 nuts that secure them are broken and need replacing
