If put on a 41 minute load, I come back and have a look and it says 27 minutes and stays at 27 minutes for 1/2 an hour or more. It sounds like it's still washing but the time doesn't change. So the 41 minute cycle ends up being over an hour. What is the problem?
SOURCE: The digital timer skips 9 minutes out of the wash
hi shotgun - sometimes the mieles with auto adjustment functions do make changes to the wash time - usually based on a smart sensor technology.
Unfortunately I have no data or information for your particular model, I have info on earlier & the latest models only. In hindsight what this function does is adjust water levels based on the load weight or amount of the wash, the computer then calibrates the water levels and accordingly the amount of time to wash.
Eg - 4 kg load would be longer than say a load 1.5kg to process - if can understand this concept. However I cannot be 100% certain it applies to your particular model, if the user manual is availbel it may just pay to read thru in case it applies to the washer.
Testimonial: "That's the first thing I assumed was happening, however there is no mention of it in the manual and it's only recently started happening...thanks"
