My internal DVD-ROM is malfunctioning and I would like to boot from a DVD using an external USB DVD-ROM. My computer is an IBM Thinkpad T22, there does not appear to be an option in the boot menu for USB.
I assume with "boot menu" you mean the BIOS boot menu (the one you get
to if you press F12 during start up, before the Windows screen appears.)
Note: I am not 100% sure if you can boot from a DVD externally.
I booted from the internal DVD drive fine with a Linux LiveCD. It is
possible that the T22 BIOS does not support external booting. Check you
version - the latest release from IBM is version 16ET32WW (1.12),
release date 06/03/2004. You find that info here.
I would really appreciate if you could come back here and leave a comment, so I (and maybe others?) can learn form this ;-)
The Thinkpad T22 cannot boot from a USB port. That's a limitation of the machine. The T23 can.
T22 *CAN* boot from USB without BIOS upgrade -- by first allowing BIOS to start minimal Linux system which contains necessary USB drivers from a supprted drive, CD, HDD and then transfer control to USB drive to boot full OS.
Detailed description, here:
Add a Commenthttps://help.ubuntu.com/community/BootFromUSB
The only option (which BTW I've tested & it works) is to use a 3-rd party bootloader with a USB Boot option like PLOOPKexec https://www.plop.at/en/plopkexec/index.h...
It can be installed over the top of all systems on existing HDD. U need to connect internal T22 HDD to another PC, ulpoad bootloader and it will boot every time T22 starts giving You option for USB boot at that time)
You should enable legacy USB support from BIOS
Thanks for the help. I upgraded the BIOS and tried many options. Unfortunately, no matter what I try, there is no "boot from USB CD" option. There is an option in the BIOD to disable the floppy controller, thereby allowing USB diskette drives to be assigned as A: but unless I can fool the computer to think that the CDROM is a disk drive, it looks like there is no way around this... Unless anyone has any other suggestions?
