Take pull string housing off. Looks like 3 or 4 screws. Should be able to restring from under side. Either buy new string or if old string is long enough, just tie knot on the end. Good luck
YOU MUST REMOVE THE STRING HEAD YOU SHOULD HAVE TWO PEICES THE IUTER HOUSING YOU SHOULD CLEAN THE INNER SPOOL REMOVE ANY OLD STRING AND LOOK ON THE BOTTOM THERE SHOULD BEARROWS TO TELL YOU WHICH WAY TO WIND THE NEW STRING
to restring it all you have to do is pop the cap of string head pull the spool out and wind your string around it in the way they say to run it.its usually on the spool wind this way with an arrow.the cap shood be pushed in and turned to unlock the cap replaces the same way
