It sounds that there is some loose contact in the connection wires inside it. Check all the flat cable connections for any loose contact. Re-seat them once, and check If you are not familiar with electronics, do not attempt to
repair. Whether you suffer fatal electrical shock!
Instead, contact the nearest service center.
SOURCE: My Sony Bravia KDL-26S3000 won't turn on and is stuck in standby.
There is a power fault with one of the PCB's inside, contact Sony if you are still in warranty, if not contact a Sony service center as it will need an engineer to open it up to repair it.
Thanks
SOURCE: Sony Bravia KDL-52XBR9
There is a error in TV.Count how many times blinking the red light.
Testimonial: "I also bought the Sony KDL-52xbr9 mine did the same thing with six blinks. I sent it back to to store. "
SOURCE: 12 little horizontal lines in Sony Bravia KDL-52W4100
we have the same exact tv and it is not even a year old. we are told that it is the display panel and it is a well known problem with this tv. we were also told that there is a shortage of these parts. they had 283 on order, but only received 35. you need to call sony and tell them that you have this problem. they should warranty this for you even if your tv is 3 months past the warranty period. since this is a well known problem with this tv, keep on them.
Testimonial: "It in fact was a part of the lcd panel...the t-con board. I was able to research it and bought a box of parts off of a tv like mine and fixed it. Ron"
SOURCE: My Sony Bravia KDL-46Z4500 keeps switching off
Power board have problems.Replaced capcitors puff up or burst open,Know how to solders?Or replaced the whole power board buy refurbish power board at Shopjimmy.com,Ebay.com.
SOURCE: Sony kdl-v40xbr1 has horizontal lines
I'm having the same problem. I have noticed on mine that the menu when brought up is clear and I can see it perfectly. The picture on all the inputs is just as described above though. BUT, like I said I can see the menu just fine. This leads me to believe that it's not the panel. Anyone have a solution to this, or at least know what could be causing it?
