You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
1. Switch off your Nokia phone
2. Now Press following key sequence *#7370# or *#7780#
3. Enter Default lock code is 12345.
4. While holding these buttons, press the power button and switch on the phone.
5. Wait for message 'Format it
SOURCE: i have nokia xpress music 5130 and it gives me
I myself own this awesome music phone.
Find the answers below:
1) As it shows less internal memory, it seems that you have transfered some data like mp3, video clips through bluetooth to this phone and it was saved in the recieved folder which autmatically saves in phone memory. Try saving the data to memory card and you will get the phone memory free.
2) Check the above reason for this same issue.
3) You need to select proper connectivity mode under settings of this phone. Go to settings and then open connectivity folder. Here select the connection mode.
Make sure to install the latest PC suite software on the computer. This can be downloaded from the NOKIA website.
Regards
Anand
Rate it, if it helps.
SOURCE: i have nokia 5130 xpress music and my phone memory
i have nokia 5130 xpress music and my phone memory reduced from 30mb to3mb
SOURCE: how i format my nokia
Usually the default security code is 12345. Go to the Menu, scroll to settings and goto restore factory settings, select restore all or restore settings only. Press Cont and enter the security code.
