Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
Fridge beeps every 5 seconds or so and fan cycles on and off
Its been doing this for a month, and now it has shut down completely. It restarted when i unplugged it. But shut down again in about two hours.
2 Suggested Answers
Anonymous
SOURCE:
kel1guy2002
Kelly
  • 3740 Answers
SOURCE: entire cooling shut down -
Hi and welcome to FixYa, I am Kelly.
The defrost cycle is usually terminated by a 60 Deg bi-metal thermostat. If the defrost heating element is not heating up the unit will shut off until the internal temp reached 60 Deg F and then restart.
Defrost cycles are 10 - 12 hours apart depending on the defrost control installed so that explains the 12 hr repeat. I really think you have a bad defrost heating element. Here is why I say that...
1. The Defrost cycle is 12 hours after last defrost. (Means the defrost control /board is working)
2. The defrost cycle terminates at 60 Deg F
3. No working defrost element will cause very very long defrost cycles due to the time it takes for the compartment to warm up to 60 deg F and terminate the defrost cycle.
The element is item 33 of this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987&diagram_id=28252332#d28252332
Just looking at the drawing it appears that the Defrost heater and defrost thermostat are an assembly.
You should be able to read resistance end to end on the heater assembly. If you have no resistance it is most likely open / has failed.
The defrost thermostat will read resistance anytime compartment temp is BELOW 60 deg F.
Thanks for choosing FixYa.
Kelly
Posted on Jan 19, 2011
Dell Vostro 230. PC will not power on completely. When the Power button is pressed, the hard drive cycles for a second, it beeps, then shuts down again.
that's easy.
1 beep? you said BEEPS, so tell me its not one beep then leave off how many beeps in a bundle.
1 beep is RTC Coin cell dead. replace. it. page 7 in the manual
2 beep no RAM found
3: beeps. mobo bad. (or?)
4 beeps. 1 ram bad or more. try 1.
5: beeps same as 1 above usually. bad battery for sure.
6 beeps video chip failures. remove card if in PCI-e slot.
7: CPU cache mem. failures, rare but if VRM bad, not rare.
i guess you meant this, ?
Vostro 230 Mini Tower Desktop Computer this is really what it is.
That beep tells you , it sees something very serious wrong.
There are 2 possibles and many tests. do you want to learn?
forget the HDD, unplug it first , focus on FANS first.
both fans, PSU and CPU must run and stay running. my guess not.
  • PSU Bad.
  • or
  • MOBO has overloaded the PSU.
so all tests are to prove 1 or 2. out.
easy no?, a binary choice.
what a tech does next is strip the PC down.
pull out the cards that are in PCI (or express) slots. run now? fans?
pull the power cables from all SATA devices, hdd ,dvd, all.
unplug all USB devices, (overkill but is done for 1 odd case )
test the mobo with CPU in and 1 stick or DDR ram'
only then try each stick of ram 1 by 1.
this is all SOP, standard op. procedures in any shop.
if a module of any kind shorts the PSU sees that and shuts it self off.
the CPU if overheated, too shuts the CPU off, dead saving its own bacon.
if stripped down PC,
just mobo, CPU and any stick of ram makes the PSU shut off
we test the PSU by itself
it that passes the MOBO is bad.
never seen any CPU short ever, VRM's lots.
the power lamp has 5 states of color.
page 7 in your manual if you want to look.
solid blue is normal others bad, black or flashing color.
RTM pg 7.
here it is, at Dell, cost nothing to read.
https://downloads.dell.com/manuals/all-products/esuprt_desktop/esuprt_vostro_desktop/vostro-230_service%20manual_en-us.pdf
Aug 25, 2018 | Dell Computers & Internet
My SDE - 120N Loads up and runs perfect for about 5 minutes and then it beeps twice and shuts down and restarts. Why?
listen to hear if the cooling fan turns on, you can probably turn it over and look through the grid, if it is loaded with lint then blow it out.. possible your CPU cooling fan is shot
Apr 30, 2015 | Computers & Internet
Washing machine will not complete spin cycle, but does complete the agiatation cycles
Have you thought of replacing it with a new front loader?
They save tremendously in water usage. Mine sames me at least $40.00 a month.
Jun 21, 2017 | Whirlpool Washing Machines
Electric furnace/air handler short cycles
check that the replaced thermostat is the same temp degree setting of the last one
Dec 16, 2013 | Goodman Heating & Cooling
Goodman a42 15
A high temperature operating thermostat will cause a problem like this. Limit switches need to be reset, but operating stats don't. Be sure your blower fans filter is clean and the ducting and path up through the furnace is clear. Stay in touch. Roger
Dec 16, 2013 | Heating & Cooling
I have a toshiba satellite x205-s9349. It won't boot at all, no beep codes or screen. The fans start and the hard drive lights go on for a bout 4 seconds and then the fans turn off and nothing....
Try this
unplug plug the power cord and remove the battery and hold the power button for 45 seconds,Then reinstall the battery and and try to start the computer,
if it fails to start
unplug plug the power cord and remove the battery and hold the power button for 45 seconds and
remove the memory and any usb devices that may be plugged in,then start it,
If it starts
Allow it to load completely and then shut it down and install one memory stick and restart, if all is well after if loads completely, shut down again and install the other memory stick and restart, if all is well again wait until it loads completely and then plug in and allow to load each of the usb devices you may have
Jun 29, 2011 | Toshiba Satellite X205-S9349 Notebook
I have a builder installed Goodman GDS80904BHA that is approximately 5 years old. Recently, when the furnace completes a heat cycle, approximately 1-2 minutes after the cycle has completed and after the...
I would guess that the fan off setting on your limit is set a little to high. If you have the manual you can see what it says about changing the running time for the fan after the burner has shut off look on the control board and you should see two switches,one to set the time for burners to fire before main blower starts and one to set time for fan to run after burners shut off. To help with the problem you are describing set fan run time up so fan wii run longer. Hope this helps. Thaks.
Nov 22, 2010 | Goodman GDS80904BNA Open Flame Heater
New Fridge beeping but no cooling
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
May 28, 2009 | Refrigerators
Won't turn off
ck to see if a wrinkle guard button is present or some such control if option is turned on most dryers will come on shut off like that for up to 12 hrs before completely shutting off this helps reduce wrinkles in clothes not removed from dryer when dry cycle completes ..if you can find owners manual consult if for a better explantion
Oct 25, 2008 | Whirlpool GEW9250 Electric Dryer
Control panel lights blink and beep, freezer fan cycles
The column between the doors being warm usually indicates that the compressor is running properly but the condenser fan at the bottom rear that cools the condenser and compressor is not running. Remove the cover from the back of the machine and verify this fan is running. It could have stuck from sitting for a period of time or something has gotten stuck in the blade during the move.
I am interested in what the fan inside the freezer is doing. You say 3-4 second pattern, is it running a few seconds then off a few seconds?
Please post back with the exact model number from the decal inside the fridge and I will look it up and see what I can come up with.
Nov 11, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
51 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
