SOURCE: How do I transfer images
Go into the menu and find "copy". It will give you the option to copy the internal memory to a card.
SOURCE: our lumix dmc-fs3 camera says the memory card is
It should have a little switch on the side. You slide it down to lock, up to unlock.
SOURCE: My Lumix DMC-FS5 camera had locked memory card,
Move the slide switch on the side of the card.
SOURCE: Lumix dmc-ts1 will not turn on after taking underwater pictures
I had the same problem, half way through snorkelling the screen just went black and the camera wouldnt turn back on, HELP PLEASE!!!
SOURCE: I have a Panasonic Lumix
There are no SD memory cards 4GB or larger because the Secure Digital standard limits card capacities to 2GB. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in the DMC-FZ30. You will need to stay with SD cards 2GB and smaller.
Select Play Mode Menu and Format wil not appear in record mode.
