Brother MFC7360N AllInOne Laser Printer Logo
A
Anonymous Posted on Jan 28, 2013
Brother mfc-7360n black lines printing on everything
303 Electronics
Level 3:
  • Brother Master 370 Answers
  • Posted on Aug 23, 2019
303 Electronics
Brother Master
Level 3:
Answers
370
Questions
0
Helped
404500
Points
2643
8chpk
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 16, 2014
8chpk
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
655
Points
Well now, wouldn't you think Brother would be monitoring this and other sites and offering their notion of fixing the problem? Nah. With my beast, the left of center vertical lines (two heavy with lighter ones in between) run more than 1/2 page length, but only in doc feeder mode. Flatbed mode working ok. Someone should rip off the feeder, disassemble, clean, and explain how that could possibly fix the problem. As far as cleaning the narrow glass strip at the left side of the flatbed, (clearly shown on the machine itself as if black line syndrome is expected regularly), someone should try that and explain how that could possibly fix the problem. Didn't do squat at my house.
5 Related Answers
Anonymous
  • Posted on May 15, 2009
SOURCE: black line down page when coping from copy feed
The small glass surface at the top of the scanner bed had some gunk on it. I scrapped it off and the line went away! Yay!
Everett Lin
  • 990 Answers
  • Posted on Dec 13, 2008
SOURCE: Black stripe down middle of page when copying
open the top cover on the left hand side glass plateform with a narrow piece glass clean it with alcohol.
Anonymous
  • Posted on Mar 27, 2009
SOURCE: I replaced all the ink and my brother mfc 240
i replaced all the ink and my brother mfc 260 still wont print black, or copy black, or test print black
Anonymous
  • 86 Answers
  • Posted on Jun 14, 2009
SOURCE: Black lines in copies and fax's Brother MFC 7420
If the black lines comes when using the ADF (top feeder), try to see if you get the same problem when using the scanner glass or receiving faxes. If you don't, you simply have to clean the glass strip to the left of the a4 sized scanner glass. Wipe it with a dry cloth piece, no paper and no water/alcohol. If you see some dirt there that you're unable to simply wipe off, try to use a cotton wool to "rub" it off.
Anonymous
  • 2306 Answers
  • Posted on Sep 04, 2009
SOURCE: Brother MFC-6490CW is not printing black
If it's under warranty you're in luck, you need a new printhead,LK3197001, around $80.00. I just replaced one yesterday in the shop for the same problem. I would call Brother customer service and see if they'll help cover the cost.
1-800-276-7746
Testimonial: "Thanks, 'komguy' :) !! That's helpful. I'll get hold of them ASAP! Cheers!"
How to repair head laser brother 7360
you do not repair them-- just replace
you can reset the error code if needed
1helpful
Mfc 7360 unable to print 7a
Error code 7A
A synchronized signal of the main motor cannot be detected.
Turn the power off and then back on again.
1 Flat cable connection failure of main motor
Check the flat cable connection of the main
motor and reconnect them.
2 Main motor failure Replace the main motor.
3 Low voltage power supply PCB failure
Replace the low voltage power supply PCB ASSY.
4 Main PCB failure Replace the main PCB ASSY.
Reset brother toner counter mfC 7360N
If you are using refilled products then your re-manufacturer needs to reset the cartridge. For these there is a particular gear placement to allow the toner sensor to reset. If you are using Brother Original products then the brother helpdesk should talk you through this.
If you are filling your own cartridges well any issues you have with this reset process are at your own risk.
Once you have completed the reset process go to the brother website and download the latest firmware update for your machine as this will alleviate most of the issues with cartridges not being correctly set.
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-style-parent:""; font-:10.0pt;"Times New Roman";}
  1. Open Front Cover.
  2. Display reads "Front Cover Open"
  3. Press the 'Clear' button
  4. Display reads "Replace Drum"
  5. DO NOT RESPOND TO THIS MESSAGE. Press '*, 0, 0' on the keypad.
  6. Press 'OK'
  7. Close Front Cover.
your machine should now be ready to print.
Why does my Brother MFC-7360n Does Not Pick up paper?
Leave the machine and attend to it at a later time repeating all you initially did.
Why is there a black line on copies when pages scanned with automatic document feeder but fine when using the flatbed scanner?
Different paper path, the MultiFunction unit is dirty - Most likely toner inside the roller or paper path. Try a laser cleaning cloth that you can buy in some stores or online. Search: Staples
If you need further help, I’m available over the phone at https://www.6ya.com/expert/william_02fc2766c1e13b73
3answers
Why brother mfc 7360n printing envelopes wrinkle paper
Do U mean wrinkle the envelopes?,,,,I can solve some MFC-9840-CDW issues, but the 7369N is a guess. Read your manual or do a google search.....There maybe a setting in the 7360N that adjusts printing for card stock and envelopes....
Brother manual feed insert paper
I am a Brother employee working for the software technical support department.
We have a solution for your printing issue posted on our solution site.
http://www.brother-usa.com/FAQs/Solution.aspx?FAQID=200000016347
Description of Problem 100000012720
When I try to print from Microsoft Word or another program, I receive a message stating: Manual Feed, No Paper, or Load Paper XX. What can I do?
Brother Software Technical Support
2answers
Norman Weimar
Norman Weimar
k24674
