My washer fills and agitates but won't spin/drain
SOURCE: fisher n pakel won't drain
Pump Belt ?
Does The Timer Stop At Particular Position? If So, Timer Failure
SOURCE: WASHER FILLS WITH WATER, THEN WON'T AGITATE.
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
SOURCE: The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
SOURCE: Whirlpool LSC8244DQ0 Top Load Washer won't agitate, won't spin, will fill and drain
you need a new lid switch google model number and order new one
SOURCE: gf1001l0ww fills spins and drains won't agitate
Check the drive to the drum and check the paddle.
It is possible also that there is no output to the motor for the wash cycle and if so the control panel board is a suspect.
