SOURCE: screen goes blank within 1 second of being turned on
Bad capcitor in the psu would cause this to squel and even pop so have it looked at you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
SOURCE: I have a ViewSonic VX2235. No picture at all
sounds like a burnt or a cold solder around the TRANSFORMER section of the power supply , I suggets if your handy w/ tools to open the monitor and inspect the PC BOARD for any burnt or cold solder THAT not making the connection , hope it helps AJ
SOURCE: When turned on, it shows the picture for a second
I don't know what zoumis is trying to say, it looks like he has a problem not a solution.. anyways..
he's my shot:
your problem could be either 2 things.. your monitor has gone bad or your video card has gone bad or may need drivers. I would try to rule out the first one. for that I'm afraid you need to test the computer with another monitor, get another known working monitor from a friend and plug it to your computer and test. if the problem is resolved there's no point on trying to fix your monitor, just get a new one.
if the problem persists, try to find out if you have a video driver problem. the first thing you need to do is go online to the motherboard/pc/video card's manufacturer website and find if there are new driver or updated driver's for your video card/ motherboard's video controller (display), download the drivers into a thumb drive.
next on the computer where you have the problem, restart and go into safe mode ( before the windows logo appears and after post is completed keep pressing f8, you will get a screen in which you need to select safemode.) once you log into safemode plug your thumb drive and install the new updated driver. you're going to be asked to restart. do so, hopefully that will correct the situation. if it doesnt you video controller is simply not working, replace accordingly.
good luck!
SOURCE: I have a n3251 viewsonic and only the sound is working,
With the tv on some channel (and sound working), take a strong flashlight or other light and bring it up to the screen. Do you see a faint picture? Sounds like the backlight has failed. Could be the power supply for it or the inverter board or one of the lamps. Are you qualified to open the unit and look around? Do you have a voltmeter?
SOURCE: Hi, Viewsonic Tv displays blank screen when
This problem is an indication that your power supply board is failing. We have an article posted on our web site at: http://www.ccl-la.com/blog/index.php/capacitors/ The article explains what the problem is and what will need to be replaced to perform the repair. If you don't want to do the repair yourself, we do offer a repair service. You can request service here: http://www.ccl-la.com/blog/index.php/service-request-form/ If you have any questions just let us know, we will be glad to help.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
