Question about LG 37LC7D 37 in. LCD HDTV
I have a LG 37LC46 lcd tv. Power is going through the set but no picture. Just error message "not programmed" and then blank screen. Happened very suddenly please can you help?
I am running free play via a PS3 that is the only thing connectved to the tv
    New Friend:
I have the picture which is why I replacer the power board that the backlight plugs in to. I don't see where I can buy the backlight bulbs. are they replaceable?
Posted on Feb 04, 2015
  • LG Master
  • 933 Answers
When the screen goes blank, dim the lights in the room. Take a bright flashlight and shine it on the panel. If you see a faint picture, you have a backlight failure
Posted on Feb 03, 2013
3 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 3 Answers
SOURCE: LG 42pc3dv-ud
Yes you need to replace the board LG 6871QYH048B. The board has a short. Check the fuses and one of them should have no continuity
because it is open.
Replace that board and problem solved
Posted on Aug 03, 2009
Anonymous
  • 21 Answers
SOURCE: lg lcd tv screen goes
I had this problem on my 42" Philips. Just got it yesterday and worked fine on the tv stand. As soon as I mounted the TV to the wall via wall mount system, I had the exact same issue you did. Figured it out today.
The wall mount was putting pressure against the center of the back of the tv (tv set had a slightly rounded back plate, and the mount was a flat plate). As soon as I put spacers (part of the wall mount hardware set) between the wall mount braket and the tv so there was no contact except at the mounting holes, the tv worked fine.
My theory is the pressure pushed the tv back plate against some board components which caused them to overheat (no air flow); or put pressure on internal connectors. I dont know.
Hope this helps, may not apply to your situation.
Posted on Sep 18, 2009
How do i connect my technics sh-dv290 to my tv and what leads do i need
i am trying to do same thing - i suggest connect ps3 via optical cable to hi fi red/ white cables via a optical/ rca adaptor, the ps3 is connected to tv via hdmi so play dvd via ps3 sound will play through hi fi - but remember dont need the yellow dvd cable from hifi dvd player to tv any more as you will be using the ps3 as a dvd player instead
Jan 02, 2013 | Technics SC-DV290 System
Tip
Stream Sony XR550 AVCHD from PC to Panasonic TC-P50G25 via DLNA with PS3
PS3 DLNA Video-Play MTS/M2TS Videos from Computer to Non-DLNA TV with PlayStation 3 <br />Full Guide to Setup Windows 7 for PS3 with DLNA Streaming to HDTV <br /> <br />The HDTV in my living room is non-DLNA compliant. It is the 50-inch Panasonic VIERA TC-P50G25 Plasma HDTV. Even though my PC is running Windows 7 with WMP 12, the videos could not be streamed to the Plasma TV via DLNA. It is quite inconvenient for home sharing. <br /><br />When looking for the solution for <b><a href="http://www.aunsoft.com/final-mate/">playing videos from PC to non-DLNA TV</a></b>, I got to know that I could download my Sony XR550 videos from camcorder to PC, connect PlayStation 3 to HDTV via HDMI cable as the media player - <b><a href="http://sony-mts-converter.com/2011/07/play-mtsm2ts-videos-from-computer-to-non-dlna-tv-with-playstation-3/">Stream Sony AVCHD from PC to Panasonic via DLNA with PS3</a></b>. The PS3 is generally used as game console. I also use Aunsoft Final Mate to join the AVCHD files from my XR550 to manage the clips for certain occasion and events. <br /><br />The first thing I do is to make sure PS3 can read the videos from PC. As Windows 7 is DLNA compliant, I just need to make sure the "Windows Media Player Sharing Service" is enabled automatically. Get the clips to the shared folder for video. <br /> <br />Note: The "Windows Media Player Sharing Service" is available in the Service section. Just right-click on My Computer &gt; Manage &gt; Services and Applications &gt; Services, and you can find "Windows Media Player Sharing Service". <br /><br />Wait for a while, and PS3 would read the video files from PC. Then for playing <b><a href="http://www.aunsoft.com/final-mate/">AVCHD files flawlessly via DLNA</a></b> with PS3, we join clips from Sony XR550 into one large file. Run Aunsoft Final Mate, and go to the Resource tab to browse the folder with the .mts files from XR550. Click the Create New Movie button, drag and drop files from Resource tab to the movie ID. Click the Export button and the files will be joined seamlessly for DLNA sharing. <br /> <br /><b>Tips:</b> <br />If the PS3 does not display the PC as source folder, we shall allow the access to Windows 7 as media server. <br /><br />Control Panel &gt; Network and Sharing Center &gt; Change Advance Sharing Settings, and you would face the window like below: <br /> <br />Make sure the "Network discovery" and "File sharing" are selected as turn on. Go to the Media streaming section and click "Choose media streaming options..." to make sure you allow PS3 for streaming. Then <b><a href="http://www.aunsoft.com/final-mate/">PS3 would read video files from PC</a></b> for HDTV playback.
on Jul 06, 2011 | Sony Alpha DSLR-A580 Body Only Digital...
No Input Signal when PS3 is connected to TV
go to your video sttings in the XMB and make sure HDMI is selected as the connection type
Mar 24, 2010 | Sony Playstation 3 (PS3) Console
PS3 Displays Static Bar Across The Screen
This is a rare problem ............ i faced similar kind of problem
i solved my problem with the help this repair guide you can also try this out i hope this will help you a lot .......
all the best
Click Here
Feb 27, 2010 | Sony Playstation 3 (PS3) Console
My ps3 is hooked up to my tv via HDMI cord. The
1 - Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.
Then after that change the output setting to HDMI on your PS3 and see if it works after that, if not, try the system on another TV to make sure its not a problem with your tv.
If it still doesn't work try another cable and then after that it could be a problem with the main board inside of the ps3.
Nov 30, 2009 | Sony Playstation 3 (PS3) Console
I cant play online without the modem being by my ps3?
Yes, using a longer ethernet cord will work, but the PS3 has a bult-in WiFi card that can connect to any wireless router (you can buy a wireless router from a computer store like BestBuy).
If you are going to buy a wireless router, see if a wireless G-mimo or wireless N with signal boost is within your budget. Try looking through the network settings to see if you can connect through the wireless router.
Or just get a longer ethernet cord and run it directly to the PS3 from the router. Ethernet cords are the most reliable connection, granted you are on a good internet connection, they won't get interference from things like mobile phones, cordless phones, microwaves, TV's etc.
I have both the PS3 and Xbox 360 and the only thing I like better about the PS3 is the free online game play and Blue-Ray. Other than that, they're even. Good luck and have fun online! If you find me (wraith0127) say hi! Don't forget to rate. Thank you!
Mar 02, 2009 | Sony Playstation 3 (PS3) Console
Line going up and down TV when i play ps3?
did you reset the setting in your xmb on your ps3 from hdmi to a/v cables?
Dec 27, 2008 | Sony Playstation 3 (PS3) Console
Hi, i have a ps3 connected to a sony hd tv via a hdmi lead. when i play blu ray movies the picture is shown at 16:9 with black bands top and bottom. the function on the tv to remove these (smart,zoom etc)...
The ps3 should do that, see if you can get one of the gaming repair guys what your situation is and im sure they will help you out with the price of nothing
Jack
Apr 22, 2008 | Video Game Consoles & Games
Ps3 won't play blue ray discs
try reseting the drive by holding down the eject button for 10 seconds
Nov 15, 2007 | Sony Playstation 3 (PS3) Console
LG 37LC7D 37 in. LCD HDTV Logo
166 people viewed this question
Ekse
RONALD CARTER JR
