Epson Artisan 800 All-In-One InkJet Printer Logo
Anonymous Posted on Jan 28, 2013
How do i clear ink pad at end of life code
I know i need to take it apart to clean out ink
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Jan 30, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
384
Points
Download adjustment program for epson to the net
5 Related Answers
Lonewolf1038
Midge Burton
  • 6 Answers
  • Posted on Jul 01, 2008
SOURCE: epson stylus photo r320 ink pad relacement
Here's 3 things you can do to get around this...depending if your printer is new and still under warranty or not (do NOT void your warranty!).
I have used all 3, but the third one was a lifesaver (AND money-saver!). About once a year I have to reset the printer using #2, but other than that....#3 is the greatest!!!
1. Try resetting it by, unplugging the power cord then while holding down the POWER STOP and MAINTENANCE buttons simultaneously while replugging the power cord caused a reset to zero on the counter. You will still have to replace the pads or redirect the waste ink tube to a receptacle on the outside of the printer, hope this helps?
2. If you go to inkjetprinterhelp.us there you will find the ssc service utility. Once you open the page click on the service utility and then choose the english version unless you can spk russian.If you then scroll to the bottom of the page and install the prog. Once you have installed the prog you will get the ssc utility logo in your bottom tray. Right click the icon and then select reset protection counter from the protection counter drop down. Once you have done this restart your computer and this should reset the system.
3. INSTALL AN EXTERNAL WASTE TANK and forget all about those gunky ink pads forever!
On the left rear of these printers is a small trapdoor held by a single screw.
Remove it, look inside (down and to your left) and you'll see the waste ink tube.
The tube is free at one end, and with a suitably curved piece of wire you can hook it and wangle the end out through the opening (you may dislodge a small piece of plastic in the process -- just put it back where it was, it's only a vibration damper.) I found the tube to be rather short....so I added an extension since I do not have room directly behind my printer for a container. I used the tubing you use with oxygen tanks or fish tank bubblers. They also make a little plastic connector so you can join the two together.
At this point, you're almost there.
All you need now is a suitable container for the waste ink, and I drilled a small hole in the trapdoor cover so you can put it back on without pinching the tube (or you could just leave it off.)
The container is a small square one with a snap-on lid, approx. 60mm square and holding about 150ml -- they're sold in sets of three for a few cents and are for making ice-blocks etc. in your freezer. Any small container will work.
Make a hole in the lid (slightly larger than the tube to let air escape) insert the tube and forget about the internal pads forever.
I've had mine in place for almost 2 yrs now and it works like a charm. If you need photos, let me know and I have a couple I can send you.
computerscot
  • 166 Answers
  • Posted on Jun 12, 2009
SOURCE: needs new ink pad
I always clean my inkjet printers using isoprophl alcohol. It dries quickly and helps remove the ink. Try that first.
Anonymous
  • 95 Answers
  • Posted on Sep 10, 2009
SOURCE: Epson R220 parts near end of life error
its a tweak with epson.... they have a counter there that intentionally stops it from working even through your printer is still in good condition.
there is an available driver that could correct that depending on the operating system you are using. i think if i maybe correct it only works with and o/s that is winxp.
the drivers name is inkpad reset utilty.
try to check the website www.epson.com/ipr for the inkpad reset utility
Anonymous
  • Posted on Feb 25, 2011
SOURCE: The printer's ink pads are
The Printer's ink Pads are at end of their Service life
Anonymous
  • 6 Answers
  • Posted on Jun 19, 2011
SOURCE: EPSON STYLUS T13 printer's ink
Epson t13 all problem solved EPSON T13 WITHOUT CHIP , INK LEVEL ALWAYS FULL, NO NEED TO RESET INK LEVEL EACH TIME .INK LEVEL AUTO RESET WHEN PRINTER SHUT OFF.INK LEVEL LEVEL ALWAYS SHOW 100 %NO WASTE INK PAD COUNTER MORENO NEED TO WORRY WHILE PRINTING MORE PRINT JOBSnow no more ink cartiledge not recognise problem
2answers
Pm235 A printer's ink pad is at the end of its service life. Please contact Epson Support.
Is that a question or a statement?? Ink pads are replaceable and can be ordered from Epson or online.
1helpful
Epson artisan 710 end of life ink pad problem
you need to get it serviced. all printers have a pad that collects waste ink, like when you run a cleaning cycle. eventually the pad gets full and needs to be cleaned and/or replaced. you could try to take the printer apart and do it yourself but I believe you will still need a program to 'tell' the printer that a service has been carried out. never done it myself but there are videos on youtube that may help.
15helpful
4answers
Epson stylus TX121 printer's ink pads are at the end of their service life
My printer name
Epson tx121
it's show "The printer's ink pads are nearing the end of their service life. Please contact Epson support".
340helpful
14answers
EPSON STYLUS T13 printer's ink pads are at the end of their service life HOW TO RESET FREE
My Cannon MP180 printer will not print is says that my ink absorber is full. What do I do?
The waste ink absorbers are pads that absorb waste ink during head cleaning cycles. One set of pads is below where the print cartridges rest when not in use. There is another set of pads at the bottom of the printer. If the error is "waste ink nearly full", press OK to clear the error temporarily.
Cleaning these or replacing them is a messy job and may not be worth it. If the printer is under warranty, get Canon to do it for you. If you decide to do it yourself, have plenty of newspaper (or other absorbant material) ready. Take apart the printer from the top; there are some screws you may have to remove to get at the pads. Then blot off most of the ink. Blot the excess ink from within the areas where the pads sit. Place the pads under running water until the water runs clear. Dry the pads; you can use a hair dryer to speed this step if you want. Then reassemble the printer.
Next reset the waste ink counter. Do not start this step before cleaning or replacing the pads; waste ink will get everywhere after a short time.
Power off printer
Hold down STOP/RESET button then Press and Hold down Power button
Keep Power button down and Release STOP/RESET button
Push STOP/RESET button twice
let go of power button
Wait 20-30 seconds - my display shows "canon Idle"
Push STOP/RESET button four times
Push Power button twice
Power off
Next time the printer is started the waste count will have been reset.
Please note that the counter is designed to be a number of pages that will be reached when the printer is reaching its end of life. Additional failures may occur soon.
I hope this helps.
1helpful
2answers
Parts inside your printer are at the end of their service life. See your printer documentation.
Q: What should I do if my printer driver displays the message parts inside my printer are reaching their end of service life?
A: See the Epson Ink Pad Reset Utility page.
Epson Ink Pads Reset Utility
If your product is displaying an end of life service message, please view and complete the required information below to proceed.
Please explain the message I am getting in my printer driver that says parts inside my printer are reaching their end of service life.
Like so many other products, all Epson consumer ink jet products have a finite life span due to component wear during normal use. At some point, the product will reach a condition where either satisfactory print quality cannot be maintained or components have reached the end of their usable life. This is the normal product life cycle for highly mechanical devices like printers. This message is a warning that certain parts have reached the end of their usable life and that your printer will no longer work until it is serviced.
What parts are we talking about?
The message refers to the ink pads, which are actually a number of porous pads in the printer that collect, distribute, and very importantly contain the ink that is not used on printed pages. Ink is collected by these pads during the initial setup of the product, during cleaning cycles and when printing borderless photographs. Most users will not receive this message before the printer is replaced for other reasons. Some high volume users or those who use the printer for many years may receive this message about ink pads before other components reach the end of their usable life.
Why does my printer stop functioning when I get the message?
Epson is committed to ensuring the proper operation of all our devices to minimize the risks of property damage or personal injury during the lifespan of the product. The printers are designed to stop operating at the point where further use without replacing the ink pads could create risks of property damage from ink spills or safety issues related to excess ink contacting an electrical component.
Is there anything I can do to continue using my printer?
Epson recommends replacing the printer, but if you want to continue using it, Epson recommends having the printer serviced at an Epson Customer Care Center. You may also be able to have the ink pads replaced by an independent service provider and use the Ink Pad Reset Utility to reset the Ink Pad Counter to continue using the printer. Please note that replacement of ink pads is relatively expensive and may not be a good investment for lower cost printers because the printers' other components also may be near the end of usable life. Epson does not recommend ink pad replacement by users without technical training or resetting the Ink Pad Counter without replacing the ink pads.
Note: This utility is for Windows XP and Vista operating systems only. We hope to develop an option for Mac users as well; however, we do not have an ETA or the OS requirement at this time.
To download this utility, please complete all fields below, select the agreement check-box and click Download. Required fields are noted with an asterisk(*). Some models may require you to be redirected to another website to finalize the process.
Go here to complete the agreement and download the utility:
http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp
1helpful
Parts inside your printer are near the end of their service life.
Most likely the waste ink counter has reached its programmed limit. You can replace or clean the waste ink pads. You need to disassemble the printer from the top; the waste ink pads absorb the ink during cleaning cycles and when you do edge-to-edge printing. Have plenty of newspaper or other material to keep the excess ink from spreading. Remove the pads, blot off most of the ink and then hold them under running water until it stays clear. Blot the excess ink from the area where the pads rest as well. Dry the pads (you can use a hair dryer to speed up the process). Then reassemble the printer. If you want to replace the pads, contact Epson Service.
Fill out the form here: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes and get the Ink Pad Reset utility. You will need to provide your printer's serial number. Run the reset program (Windows computer).
Please note that the programmed timing on the waste ink is based on the expected life of the printer. You may have additional failures with the printer in the near future.
I hope this helps.
Ink pads have outlived there life time ????? artisan 800 put in new ink and unit won't print
The waste ink pads absorb waste ink during the cleaning cycle and edge-to-edge printed pages. The pads are at the bottom of the printer under the head. If you take apart the printer, you can blot the excess ink out and then run the pads under water until they are clean. Dry well and reassemble the printer. Then you need to reset the counter. Epson offers a reset utility for some of there printers that executes under Windows OS only (available after you enter your e-mail and the printer's serial number) The URL: http://www.epson.com/cgi-bin/Store/support/InkPadsForm.jsp?cookies=no&com.broadvision.session.new=Yes
Using the reset before cleaning or replacing the pads (can be ordered from Epson Service) will lead to ink getting everywhere.
Please note that the reset point on the counter is expected to be reached under normal usage when the printer is close to the end of life. Additional failures may occur in the future.
I hope this helps.
(Start the disassembly at the top of the printer, move the printhead out of the way (sometimes it is held by screws) and fish for the pads. Have lots of newspaper or other material to keep the ink from getting all over your workspace.)
6helpful
3answers
Error masege "part end life" at Epson CX4600
i had the same problem, and i did not find the actual solution here.. the problem is just an old waste ink pad. if you move the thing that holds all of your ink cartridge, you should see a blue ink bad. replace that or get a bunch of tissue and qtips to dry it up by pressing on it (your hands will get very dirty). then you need to download a software to reset the value of your "protection counter." i got the solution from here:
http://www.edmartechguide.com/2007/11/parts-inside-your-printer-are-at-end-of.html
once you install the software, just close it (it will actually minimize it to your task bar). then right click it >> protection counter >> reset protection counter. if u want, you can even check your current value. i had 39000/36000, which is why i keep getting that error "E" or end of life. once you reset the counter, just turn off your printer, and turn it back on. it'll work like it is brand new.
HOWEVER, if you did not replace your pad, you wanna clean that thing as much as you can and as frequent because even though the value will be reset to 0, once you print that value will jump to maybe 20000 depending on how well u cleaned it. then you will have to go through the process of resetting it again (which is no big deal). hope this helped
Top Epson Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
NH TECH
Level 1 Expert
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
