The same code for making the Toshiba SD1010 will work on the SD1015KB
1) Turn on the dvd player
2) Press the eject/stop button on the dvd player (not the remote) to open the tray, and leave it open!
3) On the remote press 98790 (if done right, a message will appear stating that region has been changed to 0)
4) Done
SOURCE: multi region hacks
Try this may be work
Multi-Region:
Put DVD into player - wait for regional code violation screen to appear
Once this has occurred press the M (Memory) button on your remote
Press 1 for Title 1 and Play on the remote - this will over-ride the regional code violation detection menu
You can watch the movie by pressing Fwd on remote and change chapters by using the T (Title/Chapter) button on the remote)
or
Switch On DVD player without disc in machine
Press Enter
Press 8, 4, 2, 6 and 9
Press Enter
Player should turn itself Off. If not switch it Off
Switch player back On
SOURCE: Need multi region hack code pioneer dv-220v-k
There is no need for region hack on this unit. It plays region free and all PAL dvd's out of the box without reprogram.
SOURCE: dvd hack needed for sd-kv550
hi
only just seen this post in case of still wanting the dvd code you could try here video help
just type make model in to search for dvd codes.
riz.
SOURCE: please can you tell me
- Power On
- Open player Tray
- Press 9879 0 (0 stands for Multiregion)
- A Message appears stating that "The Reg.No was changed to region 0"
And thats it.
