Question about SWANN 4-channel/camera Dvr Surveillance System W/4 Ccd
Picture was fine on all 4 cameras then it lost color and started rolling on the monitor .
    Sergeant:
  • 333 Answers
You have the wrong settings on the DVR, go to DVR menu system or camera settings and change the setting from PAL to NTSC.
Posted on Dec 08, 2014
6ya staff
SOURCE:
How to stop pic rolling on slave monitor
hi i really don't understand what you mean, and here it is only for cameras !
Dec 31, 2014 | Sony Video Cameras
Baby monitor will not sync
I just barely had this problem and was able to figure it out.
You need to hit the "ok" button on the side of the handheld monitor. It will only let you select "add camera".
Hit ok again and it will give you a list of 4 camera's.
Now at this point you will need the actual camera and handheld monitor. You need to hold down the "code" button on the back of the camera and select "camera 1" in the list of 4 cameras. This should sync it back and you should have picture again!
Aug 08, 2013 | Summer Infant Babies R Us Baby Sight Color...
Camera monitor lost color ability
Hi
The First Years range is by Tomy - we recommend you contact them to discuss http://www.tomy.co.uk/
Jan 15, 2012 | The First Years Baby Care
Rolling screen
You either having the problem with 5vdc feeding the T-CON board on the LCD panel or the T-CON board is dying, which mean you will need new panel. Look around to see if you can see any bad caps, solder joints, etc.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Replacement board: and how to open the monitor videos.
http://www.lcdrepair.us
Jul 13, 2010 | Gateway FPD2275W LCD Monitor
Px42XR3A, NEC monitor lost picture of any type after showing a series of color bands from all sources. No other set in the house is affected and the sound through the receiver is just fine.
The picture board on your monitor is bad, since the power or button is on and sound and other things are fine, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 25, 2010 | NEC-Mitsubishi Nec Display Solutions...
Picture color is pinkish and out of focus
there might be a problem with ur monitor.
Step 1 - check these pics on sumone else's comp or open sum other jpegs just to check
Step 2 - If the pics are fine on sum other comp then ur monitor needs attention
Otherwise
use Adobe photoshop
adjustments ----> color balance to get rid of pink tint
Apr 05, 2010 | Canon PowerShot A95 Digital Camera
Picture is rolling
Pinout : Pin Name Direction Color Description
1 RED OUT Red Video (75 ohm, 0.7 V p-p)
2 GREEN OUT Green Video (75 ohm, 0.7 V p-p)
3 BLUE OUT Blue Video (75 ohm, 0.7 V p-p)
4 ID2 IN Monitor ID Bit 2
5 Gnd Ground
6 RGND Red Ground
7 GGND Green Ground
8 BGND Blue Ground
9 KEY Key (No pin)
10 SGND Sync Ground
11 ID0 IN Monitor ID Bit 0 GND=Color; NC=MonoMonitor ID Bit 0
12 ID1 or SDA IN Monitor ID Bit 1 NC=Color; GND=Mono Some systems only uses ID0 for monitor ID
13 HSYNC or CSYNC OUT Horizontal Sync (or Composite Sync)
14 VSYNC OUT Vertical Sync
15 ID3 or SCL IN Monitor ID Bit 3
Jul 17, 2009 | SAMTRON 55V 15" CRT Monitor
Monitor flickering and rolling
Thanks for the git back: #1 I hooked up a second monitor (depressed fn+f5) and was able to view everything fine. No problem in any area. Ran Some security checks (malwarebytes,checked windows updates,Secunia PSI,and a virus scan. #2 I opened up the monitor and checked for possible loose connections. #3 brought up the graphics display and checked that 60 hrz was set and correct. #4 ran a backup of all my data from my other monitor,and I made the assumption that it was a bad monitor and I might save some money if I just bought a new laptop.Would like to here your comments. Sincerely : dandee4u3
Mar 22, 2009 | Acer Aspire 3690-2196 Notebook
Rolling picture on TV while playing back Hi8 tape on TRV460
Hello richiehere,
Check and correct Color System of your TV set. I think you have Multi-Color System TV set and Its not match with your camera system.
May 23, 2008 | Sony Handycam DCR-TRV460 Digital Camcorder
Camera lens seems like its not working
CCD failure This may be a call back issue Contact Sony.
Sep 10, 2007 | Sony Cyber-Shot DSC-T1 Digital Camera
SWANN 4-channel/camera Dvr Surveillance System W/4 Ccd Logo
422 people viewed this question
Top SWANN Home Security Experts
gaucherre
Marvin
Marvin
Lawrence Oravetz
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
