Question about Kenmore Washing Machines
Dont want to save suds.( Kenmore model 5450290 Suds saver washer)
Hi, I recently acquired a Kenmore-Whirlpool Suds-Saver washing machine(model # 5450290) and I'd like to install it in a location that does not have a laundry tub to save the suds to and I'm not really interested in saving suds anyway. The problem is that it has the two drain connections on the back and I'm wondering if there is an easy remedy for this situation. Is it possible to just plug the suds saver opening and run the machine without that function or is it more complex than that? Thanks for any help, I appreciate it very much!!
Disconnect the wireing to the suds saver valve and tape the ends off.
valve will no longer open for the suds cycle
Posted on Oct 22, 2009
  • skinned_knuc Sep 20, 2010
    I have the same machine. If you pull the unit out away from the wall and look at the back of the washer from behind you should see 2 skinny hoses and 2 fat hoses. The skinny ones are for the hot and cold fill and should connect to your source of hot and cold water. The fat hose on the right is the water discharge hose. This is where the water comes out when the washer pumps it out to drain the washer tub. Newer homes without laundry tubs have this hose go into a 3 or 4 inch diameter pipe about 2 feet long that drains into the sewer pipe through a water trap. I think any home improvement supply store could explain to you how to install one. The fat hose closer to the center of the back is only used for sucking water back into the washer from the previous rinse cycle. You can remove this hose if you don't have a laundry tub (fyi you could also use a huge bucket or anything that is big enough to hold the water). The only remaining issue is that you never engage the sudsaver feature. If you look on the cycle timer on the left side (at 9:00) you will see that it says "OFF" just above that it says "SUDS" and above that it says "14". When you start your cycle be sure that you put it on "14" and not on "SUDS". That's all.
My washing machine says sud. What does this mean?
read your user manual as it could be a suds saver operation meaning that the machine pumps water back from a washing tub to conserve water when washing
Sep 09, 2017 | Washing Machines
While in the middle of wash load, an error light appears. Sd, what does this mean? kenmore top load washer model 8567165
A code of "SD" indicates the washer has entered its "Suds Routine." That happens when an excessive amount of suds is detected in your washer, and the machine changes operation to remove the suds for proper rinsing of your load. The code will clear itself once the "Suds Routine" has finished.
If it keeps doing this each load, try lightening up on the detergent.
Oct 08, 2013 | Kenmore Oasis HE 27082 Top Load Washer
Have a whirlpool model LSS7233dq0 suds saver , the water will not the washing machine to the ash tub to save wash water, banging on side brings it into cycle I have already rplaced solenoid on the...
the diverter valve for the suds saver is faulty. Go to this valve and operate it manually to see if it is not jammed. THEN TRY IT ELECTRICALLY TO SEE IF THE SOLENOID PULLS IN THE VALVE. cHECK THAT YOU HAV e the cycle switches operated correctly too. Next see if there is power at the valve at the correct time cheers T
Jan 23, 2011 | Whirlpool Washing Machines
Washer status says 8 mins of rinse left even though the cycle is finished. It keeps beeping and power cycle doesn't clear the message
It is trying to fix an oversudsing situation. If the control detects moor overamping due to suds lock it keeps trying to remedy it. This washer is a water saver and a soap saver. Add too much to the mix and it will have a cow. Here is your manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Dec 12, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
I have a Kenmore washer with suds saver. I do not
Can you provide the exact Make, Model and Kenmore model number?
Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines.
See the Sears Parts site and / or their Answer Site for manuals.
Answer:
http://www.managemyhome.com/
Parts description and possibly manuals:
http://www.searspartsdirect.com/partsdirect/index.action
Nov 08, 2009 | Kenmore Washing Machines
Sud-saver feature
Leave the button on the control panel set to DRAIN
Just to play it safe, you can cut one of the wires to the diverter selenoid valve (I think they were yellow, if I rember correctly) to make sure you don't accidentally pump water onto your floor or something.
Aug 07, 2009 | Washing Machines
Water sighpons back into washing machine
Possible your filter is clogged, clean out. Your exit hose should not go too deep into the standpipe in wall, and it should not be air tight there. The height of approx 3 feet should be maintained. You can check the exit hose by laying it to floor level to see water flow out freely, or put into sink & try 'spin'.
If things work out, rate.
Mar 03, 2009 | Kenmore 24032\24036 Top Load Washer
Why does my washing machine have 2 drain outlets?
This is a water saver or previously known as a suds saver model. The bottom one is the drain. The top one would go to a suds tub. If you set the machine on save, the wash water is pumped out of the top hose into the holding sink next to the washer. The rinse water goes out the bottom hose to the drain. The next cycle you could set the washer to the very beginning of the main wash cycle and the washer would pump the water from the tub back into the washer to be used as wash water for the second load of laundry. Yea, used water. But the first load would be lightly soiled stuff, and the next load would be old barn clothes or play clothes. It was designed to save water (about 65 gallons used for 2 loads vs. 90 gallons) and soap. (now, front load machines with larger tubs would use as little as 25 gallons for two loads.) Just hook up the bottom hose to the drain. Leave the save / drain switch set to drain and you'll be fine. To be extra safe (in case the switch was accidentally set to save) disconnect the wires at the solenoid where the drain hose splits into two at the back bottom of the washer. (right where the hoses exit the machine.)
Oct 15, 2008 | Washing Machines
Washing Machines Logo
2,386 people viewed this question
Harvey Mahal
Kristen Denison
Kristen Denison
Level 1 Expert
James Hensley
James Hensley
