How to remove panel to clean out lint for GE electric dryer model DDC0580BBLWH
most ge dryers you unplug it,open the door and look up you'll see two phillips screws there,remove them and then slide the top panel to left to remove it,then remove two screws on front panel,move front panel to the left,now you can clean out the front panel where the lint screen is,if you have a shop vac set it up to blow and blow all the lint in the cabinet up to the front so you can vac it up,this way you don't have to remove the drum,if you do remove the drum vac out the back side of the drum,if you don't want to remove the drum look inside the drum,if you see lint there vac it out through the holes,then set up the vac to blow and blow through the holes in the back of drum,vac up any lint you see,then remove the vent line,if it's a long run stick a leaf blower into the line and blow it to the outside,when you're done start the dryer,go outside and make sure the air is blowing out strong,if not check the vent line again.hope this helps you out.if you go to order parts the number you sent doesn't come up,if you remove the wh it comes up.
