SOURCE: sony ericsson xperia x10 mini pro unlock code
direct unlock your Sony Ericsson X10 mini pro using your cable and this server http://www.fonefunshop.co.uk/Unlocking/unlock_sony_ericsson_x10_server.htm
unlock takes approx 10 seconds, which is a hell of a lot faster than waiting for an unlock code.
SOURCE: i am trying to put
Contacts, Hit the options key (The one on the left with 4 dots) then Backup, and choose Sim Card
SOURCE: is it possible to salvage a water damaged sony
Yes- first thing, remove the battery. Second thing, tilt it on its side so the water drains out. Leave it alone for at least 48 hours. If it is salvageable, it should work once it's dried out
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Testimonial: "quick responce and very good answer I highly recommend"
First, try this:
If that doesn't work, or if your phone is frozen:
All data including third-party applications will be deleted from the Sony Ericsson Xperia X8. Once the wipe is complete, the phone will reboot to its factory fresh state.
The password is user defined, try the second method if you did not set a password.
Good Luck!
