Hi guys, iam new to firewall . v have purchased cisco asa 5510 firewall for ur office. i have to install it . so can anyone help me to start. i have downloaded the manuals like getting started, configuration guide book from cisco website. In the manual, it is given that for GUI configuration, use ASDM. iam trying that but not getting. i have connected cisco asa 5510 management port to ethernet port of PC, console port of cisco to PC. is any other connection or configuration needed to download the ASDM
If you can't get the manament working initially I suggest the following
Setup a console connection
Type "enable" and press enter to access priveleged exec mode on the ASA
Type "config terminal" and press enter to access configuration mode
Type "configure factory-default" and press enter to load default settings.
Assign a static IP to your PC of 192.168.1.5 and try to browse to https://192.168.1.1 (PC is plugged into management interface)
You should be prompted to begin using ASDM
The problem is your version of java, you need to uninstall java 6 update 11 or 12 and install java 6 update 6. you can download this from the archive section at the java web site. I had the same problem but this solved it.
Good luck
pls send me a line if your problem is solve
[email protected]
Hi Jaaya, Well, unless you are very familiar with configuring cisco routers, you have set yourself up for a headache -- cisco routers are not user friendly, and many require being configured from the command line. I would suggest that you find a friend or hire a trained expert to help you configure your router with you, as any mistake or misconfiguration could create bigger problems down the road (many of the security problems organizations have are the result of misconfiguration). But, if you really would like to try, consult cisco's website (www.cisco.com), as well as these two pages (http://www.cisco.com/en/US/docs/security/asa/asa72/asdm52/user/guide/getstart.html) and (http://searchnetworking.techtarget.com/tip/0,289483,sid7_gci1140584,00.html) which specifically talk about asdm configuration. Good Luck!
Hey U need to install ASDM Software in any pc to loginn
But intially u should go thro console and configure ip and passward then u can go asdm
u need go https only
sathya
how to install cisco asa-5510 firewall i searched in cisco i didnt get answer
configuration assistance
I have the Same problem - Mux
i just bought Cisco ASA 5510 Firewall, but it very uncomfortable to configure it, could please help me by show some manual or instruction how to configure ASA 5510.
I need help for configuration Firewall
I am also having a hard time figuring out the proper configuration for this equipment
my problem is that i can successful login to the web browser through ASDM but it always says "cannot load configuration of ASA", but the ASA demo works fine and CLI also works fine. i also have ASA 5510 brand new.
my email is [email protected]
Thanks in advance
