WHEN I PLUGGED THE AC ADAPTER ,THE BATTERY NOT CHARGING
If your laptop computer runs normally on your acer 5810t charger, but the battery won't charge, please try the following troubleshooting steps:
1) Remove the battery from the system.
2) Look at the connectors in the bay and on the battery for signs of physical damage.
3) Check the battery charge by pressing the status button or image on the battery near the LED's. Note: The lights indicate the current amount of charge on the battery. If all the LED's come on when you press on the butto, the battery is fully charged. If fewer lights are lit, then the battery is partially charged. If any lights flashm or blinkm there could be a problem with the battery.
4) Reinsert the battery; puch until it locks into place and the latch snaps back to the locked position.
SOURCE: Acer aspire laptop won't charge
First of all you have to determine whether it's the battery, charger or the laptop itself.
Remove the battery and boot the laptop on AC power only, if the laptop boots up you can rule out the charger and the laptop, you may need a new battery if that is the case.
Regards.
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
