Spins fine with no load. No loose springs, spider pulley fine, motor pulley fine. Basket spins freely by hand w/o noise. Spins at 1000rpm w/o load, but with any load it will not spin over 700 rpm and shakes pretty bad.
You might need a new
Motor Asm Kit part number
WH20X10028
the pic below is Motor Asm Kit that you might need okay
Motor works perfectly......
does the washing machine spin at 700mph or 1000mph what is then
With no load it spins at both 400rpm and 1000rpm in t11 test mode. when I put clothes in the machine, it will spin at 400rpm while shaking moderately, but when you increase to 1000rpm it begins to shake pretty violent and will not go past 800rpm before shut down.
can you make a video of the unit to tell me what is the problem then is that okay with you
No video capabilities. With any load it shakes like a washer with a severely unbalanced load. Without a load it spins fine. When you shake any of the dampers the whole tub moves a lot, but the springs look to be in place. I was trying to remove the front panel to check the counterweights, but I can't seem to be able to remove the control panel cover.
is the Rear Counterweight working rightly and is the Front Bottom Counterweig working rightly
the Front Bottom Counterweig looks like this
and the Rear Counterweight looks like this
Not on my unit. The rear CW sits on top an the front CW has 2 semi circle pieces, one on the top and one on the bottom.
okay then do they work the right way then
They SEEM to be tight, I can't check the front top CW because I can't remove the front panel until I figure how to remove the control panel cover
okay then you need a new CW part number WH02X10210 okay if that is the problem
SOURCE: GE Front load GCVH6600 Shakes all over the place on spin cycle
Wow...does it sound like it's about to take. You can hear it all over the house even with the door to the room closed? We have the same reason. THis started after a bout of lice in the house and we were doing many loads a day for a while. Help!
SOURCE: Grinding sound during agitation cycle on my Maytag Performa
Its probably you stator plate and rotor. But you need special tools for this repair. There a spring that is under 200 pounds of pressure and if you take the screws off that hold the plate its going to fly into you face if your dont use the special tools to depress the spring. Is it more of a clanking kinda of noise? DOes it olnly happen with heavy loads? Try this out. Fill the washer with water only. and get it into a wash cycle with water only. If there is no noise then put in like a load of towels. A heavy load. Now if you hear the noise now then its for sure you stator plate and rotor..hope this helps, but like i said you need those special tools to do this repair or injury can result from the spring part.
