Question about Apple iPhone 3GS Black (16 GB)
Iphone recovery error 23 - Apple iPhone 3GS Black (16 GB)
    Master:
  • Apple Master
  • 307 Answers
It's probably due to file corruption. Try updating your iTunes to the latest version and try again. Here's a more detailed guide: http://www.leawo.org/tutorial/how-to-fix-itunes-error-23-1334.html
Posted on Mar 20, 2018
    New Friend:
  • 21 Answers
This iphone repair is rated "easy"
Either you need to replace Charging dock connector ot you need new battery. but 90% chances you should change charging connector and it should fix the problem.
tech from iphone repair etobicoke
Posted on Feb 01, 2013
Anonymous
SOURCE:
Error 1015 iphone 3g ,stuck in recovery mode
The easiest way to fix iPhone recovery mode screen is to use the free tool called ReiBoot. i used it before and it worked perfectly for me. What's more, it is very easy. No need to connect to iTunes and hold any button on iPhone. You can try it if needed.
Tenorshare ReiBoot
Sep 11, 2014 | Apple iPhone 3G
Why am i getting error (4013) when i try to restore my iphone
The first thing you try should be change the USB port to which you connect the iPhone. Next up, change the cable that you use. Arguably, this has worked not for everyone but for a few people.
As an extreme measure, you can also try updating from some other computer which has the latest iTunes installed.
Backing Up and Going Into Recovery Mode
If you are trying to update the firmware without doing a clean restore but running into this error (even after changing the cables), it's time to cut the chase. This method is usually recommended as the last-thing-to-try but I think it's easier to get this done with right away.
  • Connect your iPhone to the computer. Fire up iTunes.
  • Backup your iPhone.
  • Now disconnect the iPhone, quit iTunes.
  • Put the iPhone in recovery mode. The short version goes like this: press and hold power and home buttons till the screen goes blank.
  • Open iTunes on PC.
  • Connect the iPhone. iTunes should indicate (through a dialog box) that an iPhone is detected in recovery mode.
  • Now go ahead and restore the device as new. This will erase everything but you will have the backup to restore from.
Some Notes
  • Occasionally, the error seems to vanish when people update to the last iOS 6.x version and then update to iOS 7. (This applies when you are on iOS 6.0, 6.1).
  • Clear out apps and app memory to free up space on your iPhone. Although this sounds very unrelated to this error, it has helped.
Jun 22, 2014 | Apple iPhone 5c
How do I recover data from iphone 4 that wont power on?
With iOS System Recovery, you can fix the iPhone and iPad Stuck in DFU mode, Recovery mode, Apple logo, Headphone mode&more to normal status. And recover all the data. Support all iOS Device with any iOS version(iPhone and iPad).
100% Safe Guarantee and No data loss.
Three Simple Ways How to restore Disabled iPhone
100 Safe iOS System Recovery Fix iOS Error Get iPhone iPad Back to Normal
May 25, 2014 | Andis ProPet Clipper Kit in Storage Case...
Iphone 5 error 4005
hi. your phone has board hardware problem cant be fix . best solution
apple store to exchange 250$ cuz its out of warranty . believe me its worth .
Feb 18, 2014 | Apple Cell Phones
Pioneer DEH-P8400bh USB error 23
In the manual Error 23 states the USB stick is not formatted with the FAT16 or FAT32 filesystem, which is the only supported filesystems supported on the unit.
Jan 16, 2014 | Pioneer Deh-p8400bh Cd/mp3/ Receiver W/...
Error 23 when down loading
Error 23 relates to restoring an iPhone or other iOS device. It means there is a problem with the device itself. Often it is said that the battery was a cause for this and having the battery replaced solved it for many.
Oct 21, 2013 | Apple iTunes
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
I dropped my iphone 2g 16GB in a toilet bowl last month. I managed to dry it out but currently having problems in restoring it. ITunes just keep giving me errors like 1611, 1604, 23 and so on. I tried to...
Hey Chee, Usually an iphone with liquid damage may cause damage to internals that may go unnoticed if it is able to work. Depending on the error message you get when restoring with itunes may mean different things.
  • 1604 is just to check your usb cable to make sure its directly (not through a hub) connected to a usb 2.0
  • 1611 and 23 are usually hardware issues that cannot be solved with a restore
Mar 08, 2011 | Cell Phones
My 3gs iPhone is stuck in restore needed/emergency call mode. I've tried to sync to different computer...same problem. iTunes does not recognize and then when I try to restore it gives a 23 error or 2001...
Use the following steps to place your device into recovery mode. If the device is already in recovery mode, you can proceed immediately to step 6.
Disconnect the USB cable from the iPhone or iPod touch, but leave the other end of the cable connected to your computer's USB port.
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the the iPhone or iPod touch to turn off.
If you cannot turn off the device using the slider, press and hold the Sleep/Wake and Home buttons at the same time. When the device turns off, release the Sleep/Wake and Home buttons.
While pressing and holding the Home button, reconnect the USB cable to iPhone. When you reconnect the USB cable to iPhone, the device should power on.
Note: If you see the screen pictured below, let the device charge for at least ten minutes to ensure the battery has some charge and then start with step 2 again.Continue holding the Home button until you see the "Connect to iTunes" screen. When this screen appears you can release the Home button:Use iTunes to restore the device.
If you don't see the "Connect to iTunes" screen, try these steps again. If you see the "Connect to iTunes" screen but the device does not appear in iTunes, see this article and its related links.
When using recovery mode, you can only restore the device. All user content on the device will be erased, but if you had previously synced with iTunes on this computer, you can restore from a previous backup. See this article for more information.
Jan 17, 2010 | Apple iPhone 3G Black Smartphone
Apple iPhone 3GS Black (16 GB) Logo
46 people viewed this question
Top Apple Cell Phones Experts
Ekse
Marvin
Marvin
Travis
Travis
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
