driver program that updates missing, outdated or corrupt device drivers that may be causing your Video Camera to experience problems, slow down or crash. Driver conflicts often create file errors, communication problems, or hardware malfunction .Try to clean the switch. Reset the memory. Otherwise you must go to repair shop camera.
God bless you
Driver Whiz gives you the tools to easily perform recommended driver maintenance and help im
SOURCE: memory card not working? ( fuji finepix Z20fd Digital Camera)
Hi there.
When you start using a memory card, you must format the card in the camera first...using the camera menu. If you don't the camera won't read the card properly. Try that and I bet it will work for you.
Rob
SOURCE: Problem in Fuji FinePix S7000 digital camera.
CCD failure image sensor failure
ur camera may be on service
advisory list just mail the fuji film with serial number i am pretty
sure they will repair free of charge it is a manufacturing fault in
some units manufactured b4 2005 u have to email them they will repair
it free of charge
http://www.fujifilmusa.com/support/ServiceSupportProduct.do?prodcat=616757
pls rate me FIXYA for this if u like
SOURCE: Describe your Fuji Finepix Z20fd Digital Camera
This Camera is the best. It takes high quality pictures and is so easy to work it has video,self timer,regular camera,and can change to b&w,sepia,negative, and many more! it has a very bright flash and is so thin its unbelieveable! and you wont ever have a problem with the lense gettin stuck because the lense dosent come out all you do is slide the front cover and its turned on!!! I LOVE IT!(They come in pink,blue,green,red,and black i believe)
SOURCE: Fuji FinePix S8000fd Digital Camera I have
Hello :
Lens error is the most common failure in digital cameras . it seems The internal coupling of the zoom lens is somewhat fragile, and a slight tap at the wrong time can mess up the system . or it could have been something as small as a bump while it was being carried in your pocket or even the sand or something like it can cause this problem . Anyway the problem is that you'll have to pay for repairs on it since technically it's not a camera error but something that manufacturers say it happened during usage. I recommend you to contact the manufacturer to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky . Some owners seem to have been able to solve the problem with a gentle bump to the side of the camera, or some gentle twisting on the lens itself. I don't necessarily recommend that- or, at least I would call Fuji first and see what they have to say about cost of repairs. Once you do get it fixed, put the camera in Playback mode before you switch it off so that the problem doesn't happen again.
PLEASE DON'T FORGET TO RATE !
good luck
SOURCE: my FUJI FINEPIX S5700 Digital Camera keeps saying
You may not be able to. However let us try. Reset all menus to default, or factory settings. Another way to do it, possibly is to remove all batteries and let the camera sit for at least 24 hours, then put the batteries back in and try it.
You may need repairs.
