Question about Westinghouse LTV-27w7 7 in. LCD HDTV
Year it was made ltv-27w7 hd 7in
Heavy dark line on right side when fill,also foggy transparment line on left side when fill.
4 Suggested Answers
6ya staff
SOURCE:
kirtec auto
  • 1348 Answers
SOURCE: My Westinghouse LTV-27w7 Black out
the high voltage circuit is shutting down.
the two most common faults are the flyback transformer,and an overvoltage condition from a blown regulator.
both are repairs where the tv is thrown out.
the days of the loose wire are gone.
Posted on Aug 22, 2009
Robert Omura
SOURCE: Westinghouse LTV-27w7 HD 7 -- after a storm - the
same thing happened to my lcd. I had it checked out and the specialist said it needs a new motherboard. You can order one @ shopjimmy.com for under $200. Just swap it out. Hope this helps
Posted on Sep 14, 2010
jdvillanueva
Jdvillanueva
  • 2098 Answers
SOURCE: when i turn on my
This is an indication of out-of-regulation condition on the power supply section. The caused of this symptoms is the leaky/dried electrolytic filter capacitor in the power supply section. It will dropped the supply voltage and sometimes it produced an overload to the chopper transformer and produces that kind of symptoms. It needs a little warm-up to make itself stable but the symptoms will get worst, time will come the unit will not power up at all.
Leaky capacitor has a physical indication of fault like bulged/dome at the top and can easily be identified while dried capacitor has no physical indication of fault. You must have a capacitor checker to determine its condition. If it is not available, you may replaced all electrolytic capacitor in the output of the power supply section. It has a capacitance and working voltage which is labelled on its body itself. Replace it with same rating. Upon installing a new capacitor, ensure that the polarity (positive and negative side) must be at its location to avoid further damaged. It will not cost you much because each capacitor cost only less than a dollar. Also if you are going to DIY, you will save $200-$300 for service fee of the technician.
If you don't have necessary tools and test instrument and can't troubleshoot the unit yourself, I would advice you to look for a qualified technician to isolate the problem.
Check also if your unit is still under warranty/warranty period, avail it because the manufacturer will fix it for free. Don't attempt to open the back cover it will void the warranty.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 18, 2011
How can i get service manual for westinghouse tv model 42B 8000 series 7
Try to go this link http://www.retrevo.com/support/Westinghouse-LTV-27w7-HD-TVs-manual/id/278dj978/t/2/ it might help
Jun 25, 2011 | Westinghouse LTV-27w7 7 in. LCD HDTV
When watching HD (i.e. channel 7.1) the screen goes blank and all controls (remote and on tv) are unresponsive. the sound works. (white-westinghouse ltv-27w7-HD)
then ur picture alone is getting affected,... this can be due to your hotizontal or vertical ICs that is the problem
Apr 30, 2008 | Televison & Video
I just purchased a westinghouse lcd led tv. half the screen is really dark on the left side. any ideas
This sounds like a series of LED's are not performing properly and may indicate a faulty set. I would recommend returning for a replacement.
Feb 28, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse LTV-27w7 HD 7 -- after a storm - the tv was the only thing affected in the house. The light comes on when the power is turned on, yet nothing else comes on - no picture and it will not turn...
Aug 14, 2010 | Westinghouse LTV-27w7 7 in. LCD HDTV
Recently glasses started to finish foggy and
MOST OF THE TIME "FOGGY GLASS" IS A RESULT OF SOAP BUILD UO IN THE DISHWASHER. IF YOU HAVE A WATER SOFTENER AND FILL THE SOAP CUP ALL THE WAY THEN THIS IS THE CASE. FILL A COFFEE CUP WITH WHITE VINEGAR AND PLACE IT ON THE UPPER RACK, RUN AN EMPTY LOAD ON HEAVY DUTY WASH, THIS WILL STOP THE PROBLEM, YOU MIGHT NEED TO REPEAT IT 2-3 TIMES BUT IT WILL WORK, AFTER THAT JUST USE AS LITTLE SOAP AS YOU CAN, IN MY GE I USE POWDERED CASCADE BUT ONLY FILL THE SOAP CUO TO THE BOTTOM LINE, WORKS GREAT. GOOD LUCK
Jun 10, 2010 | GE Nautilus 24" Built-in Dishwasher
Aug 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Backlighting issues on tv set (I think). Screen goes extremely dark after about 30 min. of viewing. Does not return to orginial brightness unless unit is left off for a long period of time
Lcd tv sets are lit by small glass florescent tubes called cold cathodes and, are powered by: ballasts called inverters... these go out just like your office florescent lighting the parts can be purchased online from electronic parts houses and, are easily replaced
May 22, 2009 | Westinghouse LTV-27w7 7 in. LCD HDTV
Hdmi inputs stopped working
It sound like the cable box or the Blue ray player is set to high - such as 1080P when the set is only rated at 720 - try scaling the output down and see if that helps
Nov 27, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
LTV-37w2HD37"Flat PanelLCD HD TV
It is fixable, but at a huge cost. A new panel can cost more than the TV. You might be able to find one with a good panel used on Ebay though.
Jul 13, 2008 | Westinghouse LTV-27w7 7 in. LCD HDTV
Westinghouse LTV-27w7 7 in. LCD HDTV Logo
18 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
