Ok i have a weird question.i have Sony KLV-40U100M.
it has a cracked screen. i know that is way expensive just to buy another lcd screen. my question is. are there other brands of lcd tvs that use the same screen as the sony KLV-40U100M.
I have the same tv with no power do you want to sell me your power supply?
If this were just about any other brand, you'd likely be able to find another brand of TV with the same size screen and swap the inverter boards and the LVDS board. The problem with Sony is that the company uses internal designations. If you have homeowner's or renter's insurance, it might cover some of the cost. Otherwise, put the damaged set on eBay (you'll get a couple hundred dollars plus shipping) and go buy a new set. Likely, any larger set for sale with a good screen is going to go for more on eBay and finding one is rare.
so not even another KLV?
my plan was to find another lcd tv that i could jsut take the parts from the cracked screen one...and put them in the good screen one.
OK, I would recommend to find same model to avoid any boards or LCD panel complications / matching problems.
Just in same model.
In another different KLV model, need to check part number of both TV LCD Panels. If part number is same then can be utilized.
Every model has its unique custom designed LCD panel (pixels and drive circuitry) and these are not interchangeable.
