Hoover H130E Front Load Washer Logo
Andrew Kelsey Posted on Jun 30, 2017
Hoover hspf157 power drain when rinsing
The washing machine starts off OK, fills and washes, when it goes onto the rinse cycle, it gets stuck on the filling with clean water cycle. It opens the valves for a short burst, about 2 seconds, while this is happening, the lights on the display panel dim, then it stops filling. If I disconnect the two inlet solonid valves, you hear a relay click, but the lights still go dim. This gets stuck until I move the program onto drain and spin.
5 Related Answers
IGGI34
  • Posted on Jun 17, 2008
SOURCE: hoover hse 130m washing machine problem
i found a squirt of wd40 worked wonders
Anonymous
  • Posted on Nov 22, 2010
SOURCE: Hoover washing machine 5.5 L
My 5,5 l wishing machein is electricity don't go to motor whot is the problem
barkencoa
Barry Coates
  • 3463 Answers
  • Posted on Nov 28, 2010
SOURCE: Hoover AM120 - Have replaced motor brushes - drum
I would recommend that you consider replacing the washer, as it certainly sounds like a faulty programme control, and they are expensive
The motor itself must be o/k, otherwise it would not function at all
Anonymous
  • 196 Answers
  • Posted on Mar 09, 2011
SOURCE: Hoover Elite 920 top loading washing machine will
first check the water is switched on to the machine. If it is then you most likely have a faulty water valve. Switch all power off and remove the top panel should be 4 screws or so. If it has 1 valve then replace it.
caroldon
  • 17130 Answers
  • Posted on Sep 16, 2011
SOURCE: HOOVER HNF 7147. BLOWS THE HOUSE RCD ONLY WHEN ON
You need to check the circuit in the wash cycle. Disconnect the power to the heater coils and see if the fuse trips. Also the voltage at inlet solenoid must be checked when the program cycle is on the wash , is not the program controller board is fault, possible a wrong output from the processor.
You can isolate the circuits, the heater, the motor drive to see if the trip stays. Also check the inlet and the drain pump on a test bench to confirm the working of the valve which will infer the case.
2answers
Commercial whirlpool washer making clicking noise not rinsing
Something could be stuck inside of your washing machines drain or the hose could be needing to replaced or the hose could be kinked or twisted or have holes in it. Or the wires are either broken or loose in the water valve or the washing machines wiring harness and have to be replaced.
1helpful
Fisher and Paykel 7.5 washing machine keeps powering off during rinse and spin cycles
The pump has a thermal safety cut out on it.
If the pump gets too hot it cut out.
Just put a new pump in and your all going again.
1helpful
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Machine will not spin or drain water.
I have a problem with my MW512AU. Sometimes it drains after wash cycle, but sometimes it sticks when it goes to spin, doesn't get up to speed, water comes on for about 10 seconds and shuts off, and it tries to spin again. If I hit the wash progress switch it goes directly to final spin and works ok. I then have to run a 2nd wash cycle to rinse the clothes. I also noticed a buzzing sound when I turn on the power point, which lasts about 3 seconds before stopping. It will come back on every 3-4 minutes for 30 seconds. This is with the machine power switch off. It powers on normally.
My hoover washing machine won't spray rinse or deep rinse on cold
Rinse cycles are normally with cold water only.
I believe you have a faulty cold water inlet valve. To confirm, put the machine on a cold only wash cycle, and see if it fill up with water.
If it does, then the valve is O.K. In that case the problem you are having with the rinse cycle is most likely a timmer fault.
Good Luck
Ash
1helpful
FISHER PAYKEL WASHING MACHINE STUCK IN RINSE CYCLE
lift the end of the drain hose see if the tub fills and goes in the rinse cycle if it works you have a syphon problem if so make your drain pipe stand longer.
1helpful
Fisher & Paykel wahsing machine GWL10 stuck in rinse cycle.
no power from the control board to the diverter.replace control board.it is about $150.00 for the part
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Freezer before Rinse
you hav'nt said if it drains. the problem just may be that you have plumbed drain hose onto a spigot on the sink drain and spigot is blanked off
Top Hoover Washing Machines Experts
ZJ Limited
ZJ Limited
NOEL
NOEL
Are you a Hoover Washing Machine Expert? Answer questions, earn points and help others
