Hello. Problem originally started as water dispensor stopped dispensing water. We changed the filter as manual said still didn't work. Then water stop going to Ice maker. When this happened we turned off the ice maker. The ice dispensor still works...almost out of ice. Not sure if this helps but before all this happen the ice maker would continue to make ice even after full. Any help would be appreciated; Actual product is GE Mod# GSS25WGPH
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
I have the exact same GE model (GSS25WGPH) and the exact same problem. Water dispenser stopped working, switched out new water filter, still no water flow.
water dispenser stopped working but still makes ice, put in new filter still a no no
I HAVE THE SAME PROBLEM.. AFTER CHANGING WATER FILTER NOW THE WATER DISPENSER IN THE DOOR HAS STOPPED DISPENSING WATER.. I TAKE OUT THE SMART FILTER AND SHAKE ALL THE WATER OUT OF IT, THEN REPLACE IT, AND A GOOD STREAM COMES OUT FOR ABOUT 2 SECONDS AT FULL SPEED AND THEN STOPS.. ANY HELP????
I have the same problem.. when i changed the filter it ran for about 2 seconds at a good speed and then stopped completely.. so i took off the smart filter and shook all the water out. then replaced it and it ran again at full speed for about 2 seconds and stopped again..
please help.\
Has anyone verified the shortened plastic theory?
After I replaced the water filter of my GE GSH25JFTC fridge for the first time, water only dispenses for 2 secs and then stopped. When I switched out the filter and put in the filter bypass plug that came with the fridge, water dispenses ok. I'm guessing that it's a filter problem.
