Check the shielding of your antenna. Moreover make distance between VCR and antenna cable. In fact VCRs have a built in modulator and its signal is strong as compared to local antenna signal. There is another way, connect the local antenna in VCR RF In and connect RF Out of VCR to TV. In this scenario you have to tune your VCR to get the antenna channels instead of TV. It will solve your problem.
If you are seeing snow on your Symphonic TV screen, it could indicate that the TV is not receiving a signal from your cable or antenna. Here are some steps you can take to troubleshoot the issue:
Check the cable or antenna connection: Ensure that the coaxial cable or antenna is securely connected to the TV and the wall or source.
Run a channel scan: Perform a channel scan or auto-programming to ensure that the TV is tuned to the correct channels and that it is receiving a signal.
Check the TV's settings: Make sure that the TV's input is set to the correct source, such as cable or antenna. Also, ensure that the TV's settings are not set to "mute" or "no sound."
Try a different device: If you have another device, such as a DVD player or gaming console, try connecting it to the TV to see if it is able to display video and sound.
If none of these steps work, you may need to contact a professional technician or the manufacturer for further assistance.
Without more details there is only a couple of conclusions - maybe the set top box you have is faulty or incompatible in some way with either the tv or the antenna.
Incompatibility with the tv seems unlikely as presumably the on-screen menus generated by the box are displayed satisfactorily - allowing you to select a menu, scroll and select an item and then view the channel seeking process. If this is so it suggests the connection between the box and tv is good.
That rather suggests the box is faulty or the antenna is faulty or incompatible.
Hi. By static, do you mean 'snow' image ? DVD players must be connected to AV inputs and selected as an AV signal, either by using the remote control, either using the local controls in the set itself. If you see, what you call static, means that your TV is on "a" channel without areal input. (antenna inputsignal).
You can use the local TV channel button (-), go all the way down below channel 1. There the AV inputs are located. Good luck.
You may be looking in the wrong place or have the wrong kind of antenna. With the digital conversion, TV channels shifted from the numbers they used before. In my area, the previous Channel 6 is now broadcasting in the UHF band.
It can be harder to adjust the antenna for a digital TV because it is either working well or totally off - no gradually decreasing "snow" as a clue.
It is possible your TV is not equipped to pick up digital TV. There are converters to translate digital TV to analog signals for older TV. They cost between $30 and $70 depending on features.
HD tv is picky about the signal. You either get a signal or you don't get a signal (no static or snow). It really depends on your location as to where you live. There are ways that you can find out how close you are to a transmitter by checking on Wikipedia for each channel in your market. It will give you precise position as to where it is. It will also tell you if they will broadcast in 1080i or 720i. Check the antenna specs to see what the range is on the rca.com website.
There are many variables here that could cause the problem. I can receive a few local HD channels ( within about 60 miles ) on my 57H94. I am not aware of any "HD specific" settings- it's all part of the receiving circuits in the TV. The first thing I would look at is to be sure you have a secure antenna connection. Then be sure you have selected the correct antenna input on the TV (there are two). HD channels, as an example will show up as 10-1, 10-2, etc. Most TVs have different sensitivity thresholds, regardless of size. Usually digital signals, including HD, are either there or not. In most cases if a TV picks up a decent analogue signal, a digital set should receive the digital signal, including available HD channels, as well. If you are going to use an antenna, rather than cable or satellite, try to get the best antenna you can afford, that will meet your physical requirements ( indoor / outdoor,etc.). Keep in mind that not all digital TV signal are HD. All of our local stations in this area transmit a digital signal, but true HD broadcasts remain variable. I hope this has helped in some way-Good Luck!
Sounds like U have an antenna or feeder problem. Get it checked out/ check it out. If in a strong signal area, try a simple indoor antenna for comparison. If in a marginal reception area, it could be your antenna is inadequate.
My friend, you need to hook up a signal source such as an antenna or cable . The channels wont come in and it will all depend on where you live and how close to a major city on what and how good you will get the stattions. then once an antennena is connected, do the auto programming again. Good Luck
