Bonjour, I had a probleme with my cambridge ,the output sometimes doesn't work, sometimes its the left or the right way. I turn the volume or the balance buton or i change the system,cd''s to tuner for exemple and it's go well for the next time what is it please?
SOURCE: cambridge 640 amp, levels coming out r and l are different
Adjust "Balance" to center. If at center, something more serious in amp.
Paul
SOURCE: The left channel in my cambridge azur 640
have the volume control cleaned by a spray of electronic contact cleaner. If the carbon coating material is already wiped-out due to use, have the part replaced
SOURCE: I have cambridge audio azur 640a amp. Problem I
The fault is on the amp! It sounds like the protection circuit is detecting a surge on the channel and shuts it down to protect the speaker. I would check the semiconductor device(s) for the right channel on the heatsink of the amp. You might even see damage of burning on one!
