I am receiving a Touch Pad Failure (5) on my Simon XT. Any help will be appreciated.
SOURCE: What resistor is required?
The 4.7k ohm resistor (1/4 watt is fine) is only needed if you want the siren to be supervised (i.e., the alarm to go off if someone cuts the wires). If the siren is inside your premises (i.e., in the house or the garage) and therefore unlikely to be attacked, you don't need the resistor. (Hardware supervision is disabled by default on the Simon XT, so if you do wire the resistor, it won't do you any good unless you enable hardware supervision in System Configuration.)
SOURCE: Simon XT panel does not want to learn motion sensor
try learming the sensor in by removing the back and actavation the tamper switch of the unit. also make sure that the unit is not already learned into the unit and if all else falil default the panel and start over.
mj
SOURCE: Remote touchpad for Simon XT stopped working
reprogram the unit to the Simon3
AlarmProfessor,net
SOURCE: GE Simon XT how do I reset the code
You neet to reset the system to factory defaults. Contact me and I can go through it for you.
AlarmProfessor.net
SOURCE: will the sencors that are on 60-875 work on simon xt system
No,sorry they are totally differnce in system datas programming.
